T56 Installation
Old Jan 18, 2001 | 11:45 AM
HighHorseZ's Avatar
T56 Installation
I plan on swaping out my 700-R4 for a T56 in the spring. Is this a project that can be done in my driveway? I'm thinking that it would be difficult to jack the car up high enough to get the old trans out and the new one in. Also, I know that I have to cut the floor pan about 1 inch back for the new shifter, but if I cut it back an inch isn't the shifter going to hit the interior plastic counsol when I shift into 2, 4, and 6th?
Thanks,
MIke
Old Jan 18, 2001 | 12:12 PM
ScreaminDeamin85Z's Avatar
i believe that you read the installation instructions for a T-5 car. you will have to cut a descent size hole in your floorboard, not just an inch. as far as the height to get the auto tranny out, it is up there but not too high that a 3 ton jack wouldnt do. it can be done in your driveway, just the other day i pulled my 700-r4 out while it was raining in my backyard.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR
(dont worry i am switching to the 89 ECM)
Old Jan 18, 2001 | 03:03 PM
Birmass's Avatar
I put a 95 t-56 in my car that was originally a 700r4. I had to cut about a 4x6 inch hole in the floor. The shifter handle was actually closer to the front of the plastic console than to the back, but it does not touch. I took a hack saw blade and cut out the old automatic gear select plate and made a shifter boot to fit under the lip of the console. It fits perfect and I have fulled everyone into thinking it's a factory 5-speed console. Go for it. I did mine in my garage with a jack, ramps, and two jack stands. By myself too
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
BlackphantomZ28
Aug 31, 2015 10:29 AM
86iroc z Z28
Aug 21, 2015 10:37 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
