Smoke from rear in corners
Old Sep 29, 2008 | 05:44 PM
Alminate's Avatar
Car: 85 Camaro
Axle/Gears: 3.42 posi
I installed a 3:42 LSD from a 4th gen into my 85 camaro.
On long corners, like a highway on-ramp if I give it any gas smoke starts coming from the rear of my car. I'm not sure what it is coming from. I don't feel any traction loss, like it is smoking a tire.
Do rear ends ever smoke, or is it just tight and locking the wheels?
Old Sep 30, 2008 | 08:23 AM
Alminate's Avatar
Car: 85 Camaro
Re: Smoke from rear in corners
Old Sep 30, 2008 | 09:05 AM
big gear head's Avatar
The tires are probably rubbing on something when you put a side load on the suspension. Remove the tires and check the frame and other areas under the car for signs of tire rub.
Old Sep 30, 2008 | 06:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
did you put the panhard bar back on?
Old Oct 1, 2008 | 11:44 AM
Alminate's Avatar
Car: 85 Camaro
I did put the panhard bar back on.
I also had to put my stock springs back on the rear & some bumpstops which where missing. (i noticed that on the first drive with the rear, the tires would hit the fender lip on corners)
I don't feel any vibration when it smokes, like the vibration I felt when the tire was actually hitting the body?
Frozer!!!
Jan 19, 2024 04:55 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
86White_T/A305
Aug 17, 2015 12:16 AM
