Diff Pinion Oil Seal Replacement?
Old Jan 19, 2001 | 10:55 PM
Jono2's Avatar
Hi,
can anyone help me with some advice on how to change the diff pinion oil seal on an 86 Iroc with a 305 and 5sp man??
Thanks in advance.
Jono.
Old Jan 21, 2001 | 09:08 AM
ede's Avatar
ede
remove drive shaft, make a mark on the nut and pinion, or something for referance. remove nut and yoke, remove seal. install in reverse order. tighten nut and match the lines up you made. i'd use some red locktite on the nut.
ICON Motorsports
1st & 3rd
Old Jan 21, 2001 | 09:09 AM
ede's Avatar
ede
damn i thought i answered this before, you posted twice. i respond to so many threads it's hard to keep track sometimes.
ICON Motorsports
1st & 3rd
Old Jan 21, 2001 | 01:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Before you start, you need to feel the amount of resistance is in the yoke when you turn it. Once you reassemble, you need to tighten the nut down so that there is just as much if not a little more resistance. If you do not give the pinion bearings the same amount of preload, they might last two weeks.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
