Poll: which way did you install the m/c on your 700R4-T5 swap?
Old Jan 20, 2001 | 10:54 AM
Tom Keliher's Avatar
I am at the point that I am ready to install the clutch master cylinder into the holes I drilled in the firewall. For those that have done it, or even replaced a bad m/c, which way is the preferred way to install it?
Options I see are:
1) try to wiggle it in from the top with everything in place as is
2) remove steering column coupler for more clearance
3) try to wiggle it in from underneath the car
All 3 look like a PITA, but there is probably a preferred method. How have you guys done it? Thanks!
Old Jan 20, 2001 | 11:27 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
stand on drivers side by fender, have a friend in the car. The person outside takes his right arm under the brake booster and his left arm over it. U wiggle it enough for a friend to put a screwdriver in the eyelet end of the hydraulics then he gently starts to pull with the person outside straightening out the m/c. If it goes right at the same time the slave lines up perfectly with the hole for the hydraulics for the bellhousing.need more help lemme know i could help u today until 3 lemme know
89 Firebird (AKA "Money")
2.8 V6 w/ t5 tranny (383 tpi t56 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
Next:
Spohn Torque Arm, Lakewood Panhard bar, BMR Fabrication Sub Frame connectors...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
Old Jan 20, 2001 | 11:28 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
From above.
It is in fact not very difficult. A few months ago I had to replace the entire hydraulic assembly: the slave cyl, master cyl, and reservoir, as they come form the dealer, all hooked up and pre-bled. I did this in a church parking lot where the car coasted to when the line burst, with only a floor jack and a few sockets and wrenches. It's not as hard as it looks.
ICON Motorsports
Old Jan 20, 2001 | 05:22 PM
Graeme, thanks for the offer! It's done!
RB, you must be a wizard!
Old Jan 21, 2001 | 02:01 AM
cfabe's Avatar
When i installed the slave cylinder, I just stood in the engine compartment. Of course, this method is slightly more difficuly when the engine is still there.
82 T/A 305/TH350; soon to be 350/T-5
Old Jan 21, 2001 | 08:47 AM
327 firebird's Avatar
Hey I changed my clutch M/C the same way standing in the engine bay.... So much easier when the engine isn't installed
Old Jan 21, 2001 | 10:09 AM
LOL
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
Old Jan 22, 2001 | 10:11 PM
84FTA's Avatar
Heh. I replaced my O-ring seal from the hose to the slave on gravel with the car jacked up on bricks found near by when the car broke down in the hood (I swore someone was going to come and try to steal the car off of me). I've got to hand it to RB though that's about 2x the job I had.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-tops
4-bolt main 350, headers, Holley 650, T-5, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Jan 22, 2001 | 11:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well I gotta admit I did have my 11-yr old son helping... one helluva mechanic. He held the U-bolt thing (#15 in the other post) in place while I started the nuts. Couldn't have done it without him.
ICON Motorsports
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
anesthes
Mar 10, 2016 10:35 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
