Shift RPM
Old Jan 23, 2001 | 10:41 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
Shift RPM
I got an easy question for you guys. At what RPM does your transmissions shift at WOT? I have an 89 Iroc. It had a factory 350 in it, but sometime in it's life it was replaced with a 1983 305. I just got the car on the road, and in preliminary testing she shifts on her own at 6 grand. The trans doesn't appear to have been messed with. What do you guys think?
Old Jan 23, 2001 | 11:38 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
6000 is really high for a 305, a stock L98 is supposed to shift @ about 5000. An 83 305 should probably shift at about 4500RPM.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 226/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
13.24@104
Old Jan 23, 2001 | 11:49 AM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Well, for me, WOT wouldn't shift me untill 7,000+ RPMs.
i own a 1986 IROC Camaro, with a 305 TPI "L98".
Someone had put spacers on my throttle valve cable. i took them off, and now i shift at around 6,600 at WOT. not sure about the 305 redline.
Old Jan 23, 2001 | 11:57 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Thanks guys, I'm just wondering what they did to make it shift that high. I don't think an old 305 will last too long, with me turning her like that. I was just interested in what it was supposed to shift at.
Old Jan 23, 2001 | 01:01 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
305TPI is an LB9, the 350 is the L98. The 305 redline starts at 4500 and is dark red by 5000 on the lower output 305's like an '83. Adjust the detent cable by pulling it out towards the front of the car.
Old Jan 23, 2001 | 01:04 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
I don't think my 305 came out of an f-body. I had a friend check the numbers on it and he said it was a generic 83 car engine. Probably out of a sedan or something.
Old Jan 23, 2001 | 06:53 PM
jaymz's Avatar
My 86 IROC with a TPI 305 would never shift above 4500 in drive,the trans in my 350 car shifts around 5500rpm. this can be changed by replacing or modifying the governor.
Old Jan 23, 2001 | 08:17 PM
chevyboy07 91's Avatar
I had a TBI 305 that shifted at 6000 RPM under full throttle w/ just an open element. Before the open element it would shift somewhere in the 5000 RPM range. Now, my 327 revs to the moon!!!!!!!
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Jan 23, 2001 | 09:38 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I got a TCI Streetfighter and wuz dissapointed by the whimpy 4500 shift. But for some reason it gradually increased to 5800. Right where I want it! I'm not sure if its from "stretching in" the governor springs (I was about to change them to get the shift in the ballpark above)
You can change your shiftpoints by changing your weights/springs but I never followed up on it. The TV cable plays a smaller role in shift points but I think thats a quick-fix method and not the proper way to change it.
Old Jan 23, 2001 | 09:50 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
I would tell you were my Trans shifts but my tach is off right know. (new one is on the way) But it shifts from 1-2 at 37 and 2-3 at 71-72. I set mine according to this web sit and i haven't had any problems with it yet.
http://205.178.174.23/sumner/techinfo/700R4p1.html
Lots of good info on this page. Hope that helps.
89 RS Conv 305 700R4
85HO heads
Edelbrock intake
Holley 600
Hedman Hedders and Y pipe
Old Jan 24, 2001 | 07:44 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Thanks guys. I will make sure my TV cable is adjusted properly, and see what happens.
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
