3.73s, need to recalibrate speedo ASAP
Old Jan 22, 2001 | 05:57 PM
89BlwnRs's Avatar
I just put 3.73s in from 3.08s. This means that my speedo is reading about 125% of what it should. GM doesn't make speedo gears to fix the problem, does anybody know how I can fix this? I've heard of speed shops building some kind of add-on box with another set of gears to fix the problem. Anybody know anything about this???
Any help is greatly appreciated and needed,
Jason
Old Jan 23, 2001 | 01:20 AM
Omar's Avatar
Manual or automatic tranny, and what size tires?
[This message has been edited by Omar (edited January 23, 2001).]
Old Jan 23, 2001 | 12:42 PM
89BlwnRs's Avatar
Stock T-5 tranny and the stock 15" wheels and tires. The diameter of the tire when mounted is approximately 25" if that helps you all (I measured).
Jason
Old Jan 23, 2001 | 10:36 PM
89BlwnRs's Avatar
btt
Old Jan 24, 2001 | 01:11 PM
89BlwnRs's Avatar
Come on now, somebody knows something about this.
Jason
Old Jan 24, 2001 | 05:37 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
89BlwnRs,
I'm in the process of having my gears changed from 2.73 to 3.73. My car being an 86 has a mechanical driven speedometer, yours has the electronic so the regular ratio boxes wouldn't help you. Either of these sights can help you. Try:
http://www.specmo.com/NewFiles/Calib...libration.html
They deal with factory instruments as well as other things. I know they sell something that will work. For pricing and such you could also try:
http://www.speedometershop.com/ratio.html
Hope this helped you out
[This message has been edited by ryn28 (edited January 24, 2001).]
Old Jan 24, 2001 | 06:00 PM
89BlwnRs's Avatar
Actually I have a mechanical speedo, at least I'm pretty sure. Anybody know what 89s have?
Jason
Old Jan 24, 2001 | 06:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
89 Camaros have the cable speedo, and if you searched this board, you'd have seen that you need a 7 tooth purple drive gear, and a 21 tooth driven gear. I dunno its color, I think red?
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 24, 2001 | 06:50 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
You can get almost any t5 speedo gears from here. mike@forestparts.com
Old Jan 25, 2001 | 01:59 PM
Kevin91Z's Avatar
Kevin, that email address bounced. Are you sure its correct?
Old Jan 25, 2001 | 03:01 PM
89BlwnRs's Avatar
Well Kev, you were right about the 7/21 combo, except I just got off the phone and GM doesn't make a 21 tooth gear, just a 20 and 22. The only problem is the 20 tooth gear is $45.71.
But there's hope, instead I can buy a ratio adapter for $50 that'll get it pretty close, and I don't even have to remove the tailshaft of the transmission. Sounds good to me, just lettign everybody know about this.
Jason
Old Jan 25, 2001 | 06:02 PM
Kevin91Z's Avatar
What?? I need a 20 tooth gear for my setup! I was told they didnt make one. Maybe they dont make them for electronic speedos. The 21 tooth gear is stock in 3.73 cars from 83-85. Weird that they stopped making it. Someone mentioned that earlier.
Old Jan 25, 2001 | 06:27 PM
SlowCamaro88SC's Avatar
before i ditch the car....... ok I have a '85 4 banger/5 speed firebird parts car (it's an SE tach, nice interior, 14" wheels and all) and I have a '88 camaro 2.8/auto. other than swapping out the rear to get the maro up to 3.73's where can I get this "gear" from the firebird to have my speedo read right????
  • 1988 Camaro Sport Coupe
  • 2.8 V6
  • TCI 3200 Stall TC
  • B&M Transkit
  • 2.5" 80 Series Flowmaster & Catback
  • Hi-Flo Kitty
  • '83 Z/28 Hood
  • '87 IROC Wheels
  • '92 Z/28 Bowtie Grille
  • IROC Gauges
  • IROC Taillights
  • IROC Foglamps
InfernalVortex
Apr 20, 2021 11:31 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
JSDaddy189
Sep 26, 2015 03:50 PM
92projectcamaro
Sep 24, 2015 08:09 AM
whyt86roc
Sep 10, 2015 10:03 PM
