older engine drop, will it fit the T-5?
Old Jan 25, 2001 | 09:44 PM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
well story goes, i got a vette, engine spun some berrings (damn broken idiot light) and we did a massive rebuild. so the engine is strong as hell, however right now it is just sittin. its getting prepped for paint and body work has been a long deal. anyway i want to paint the engine compartment when i do the color change to the vette, and having a engine sit is bad, so i wana drop it in the 'ol TA. give it some pep (a buttload of pep), and keep the vette engine running at the same time.
my question is: Will a '79 4-bolt main 350, fit a 85' T-5 tranny with little or no problems?
will i need a higher grade flywheel or clutch?
(highly doubt it but) Driveshaft?
the L-82 (vette) has about 350hp at the fly and redlines at 6700. if that helps.
1985 WS6 Trans AM
T-tops
bone stock sloth of an engine LG4
T-5 tranny. thank god, i couldnt stand an LG4 auto.
Plans for an LT-1 or LT-4,
dual flowmaster exaust,
& a pounding stero.
mods right now include a radar detector.
Old Jan 25, 2001 | 09:53 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
it should, the bolt patterns have been the same since 1955 i think.
but... T5s suck a lot, they just cannot handle much torque!
Old Jan 25, 2001 | 11:45 PM
85ws6TA's Avatar
as in loss of traction, or breaking tranny? cuz i dont need to break anything that isnt broke.
1985 WS6 Trans AM
T-tops
& a pounding stereo.
Old Jan 26, 2001 | 08:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It will bolt right up as if it was made for the car, except for one detail. You'll need to get a 153-tooth flywheel for the one-piece-rear-main-seal design crank, like from a 83-85 Camaro or Firebird. If your existing T/A clutch is old, now would be a good time to get a new one, and save yourself the trouble of taking it back apart. I have the Centerforce Dual Friction, and I really like it.
You can avoid trashing parts if you restrain the enthusiasm of your test drives somewhat. I have quite a bit more flywheel horsepower than that (400 with a big roller cam) in my daily driver with a T-5; as long as I don't dump the clutch or speed-shift it, the trans is OK. Do either of those things more than a few times and you'll be rebuilding a trans real soon too.
ICON Motorsports
Old Jan 26, 2001 | 11:17 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
What? Aren't 85 and 79 (the two cars in question) both two piece RMS blocks?
Old Jan 26, 2001 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're right 99, my bad... flywheels are the same. He won't have even that obstacle. Should be a slam-dunk.
ICON Motorsports
Old Jan 26, 2001 | 03:55 PM
Hype's Avatar
RB, I'm going to be dumping a 350 in place of the old LG4 within the next while (boy I keep saying this) and I am realizing now the clutch is somewhat bagged. I have an older T5/Clutch setup, ('83) any recommendations as to a decent aftermarket setup capable of handling the ~350ft/lbs I will be throwing at it?
Later,
Hype.
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
Elliswon
Aug 10, 2015 12:33 PM
