Stupid Question
Car: 1989 Firebird Formula
Engine: 350 ZZ3
Axle/Gears: Stock
Stupid Question
I've always used ramps to work on my car but anymore its just a pain in the @$$ since my wheels are so wide. So i bought a pair of jack stands. My question is...Is it safe to use jackstands on the axle and can you use them in the front. I've heard that if u do it wrong you can mess up your suspension. Thanks for any help
89 Formula 5.7L
ZZ3 with some good mods
89 Formula 5.7L
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
i put mine on the axle shafts in the rear, the swaybar is taking most of the load. In front, there is a lip that is on the control arms just outside of where they bolt to the subframe. my jackstands fit perfectly there.
hope this helps
hope this helps
No such thing as a stupid questions.....only stupid results from not asking!! I drive up two two-by-fours (length-wise), to give me room underneath for the hydraulic jack. Once in the air, I place a jack-stand under each lower control arm. Then I lower the jack. Same for the rear.
IMPORTANT: DO NOT JACK UP ONE CORNER OF THE CAR AT A TIME!!! A little bit won't hurt (like changing a tire, just enough), but do not jack it high to place a jackstand under, then go to the other side!! just my .02
'88 Formula 350
Bright (VERY bright) red. Mods? yep, but never enough!
Check out the newest f-body site: http://www.lastgen.com/
'88 Formula 350
Engine: 350 ZZ3
Axle/Gears: Stock
Ok thats the what i remember my mechanic telling me. Good stuff. Guess i'll be going to buy another jack now.
