Dropping rear end, need some help
Old Oct 13, 2008 | 12:43 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I've got the flex line cut, shocks off, driveshaft unbolted, springs out, E brake unhooked and all I have to do is remove the torque arm and the arms attached to the rear end, but I would like to reuse the bushings, how do I go about removing the bolts without having to cut the arms?
Old Oct 13, 2008 | 01:04 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
Re: Dropping rear end, need some help
wd 40, a large wrench and 3/4 ratchet.
Old Oct 13, 2008 | 05:56 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I don't understand the problem. You were able to take out the shocks, springs, driveshaft, but you aren't sure how to get the control arm/panhard rod bolts out?
Old Oct 13, 2008 | 08:08 PM
Kevman's Avatar
Engine: 2004 LQ4
Well to put this lightly... I just cleaned up a 10 Bolt 7.5 Posi that was given to me, someone had torched off the control arms, and left the bolts in. In order to get them out, we had to hack off the nut side with a cutoff wheel, and grind the head off with a grinder, and then pound out the remaining pieced.. It wasn't fun..
Old Oct 13, 2008 | 09:22 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Why couldn't you just take the nut off the bolt and slide it out?
I still have no clue what you are trying to do or what the problem is...
Old Oct 14, 2008 | 04:48 PM
Kevman's Avatar
Engine: 2004 LQ4
I had to grind off one of the bolt heads.. As i was pounding it through it stopped at a certain point and would no longer move. What now, Do I just torch the rear end off?
Old Oct 15, 2008 | 03:52 PM
Kevman's Avatar
Engine: 2004 LQ4
To clarify this, I cannot seem to remove the bolts holding the rear control arms, and torque arms. They have a taper in them, and I don't understand how to get them out, is there a trick to it?
Old Oct 15, 2008 | 04:01 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Same thing happened to me, I cut the head of the bolt, then I had to cut the bolt on the other side with a hacksaw (inbetween the mount and the bushing on the nut side). You can't slide the bolt out by cutting the head off, you can try to cut the nut off, and then try to get the bolt to slide out toward the head side of the bolt. But it's probably rusted in there pretty good. No point in trying to save the bushing, most likely it needs to be replaced anyways.
Later
Old Oct 15, 2008 | 05:48 PM
Kevman's Avatar
Engine: 2004 LQ4
Ahhh! It makes sense now.. They aren't rusted in, but I couldn't figure out why it was so difficult to get it out with the head cut off. Thanks a ton man.
Old Oct 16, 2008 | 02:44 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
I just did this to my car, and that part is a 2 man job, i sprayed pb blaster on the bolts all day, and got a huge adjustable wrench to hold eh head of the bolt and took my biggest breaker bar to the nut. Its a pain in the ***, but eventually the move out.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
