shift kits
Old Feb 5, 2001 | 12:47 PM
ArnoldBraker's Avatar
shift kits
What is the difference between a shift kit like one that hurst makes, and putting your auto tranny in 1st and shifting like that? Does the shift kit just affect how crisp the shifts are? Thanks~Arnold
Old Feb 5, 2001 | 02:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Hurst makes a shift kit?
Old Feb 5, 2001 | 03:32 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Maybe he meant a shifter?
Shifters don't make the car faster, or shift differently, than before.
They've got two purposes: 1= They look cool, 2= Some ratchet ones make it impossible to hit the wrong gear by accident.
There's only one way a shifter will help you- if the original shifter and shift cable are so worn out that they're not engaging the detents inside the trans fully.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 5, 2001 | 04:03 PM
chevyboy07 91's Avatar
Hurst DOES indeed make a shift kit. It's called "Hot Shift". I was actually gonna run it in my tranny but decided not to. I haven't EVER heard anyone talk about it either.
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Feb 5, 2001 | 04:04 PM
SIG
Old Feb 5, 2001 | 04:05 PM
? sorry
Alex (AKA chevyboy) '91 RS 327, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Old Feb 6, 2001 | 03:38 PM
So then a shift kit is what makes your shifts crisper, which hurst does not make. So can you buy a shift kit and use the stock shifter? I am kind of confused:-) ~Arnold
Old Feb 6, 2001 | 03:42 PM
Hurst DOES make a shift kit...............and yes, this is what makes your shifts crisper. You do NOT need a new shifter.(The thing that you use to select park, drive, reverse, etc.) I haven't personally seen the Hurst kit for the 700 R4 in particular, but I've seen them for the TH 350's so I think they prolly make one for the R4 too.
Old Feb 6, 2001 | 03:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Hurst makes a shift kit for the 700 R4 Its called the HotShift 2 made for 92-93 trannys with non-lockup converters Part Number HUU-2858635 but summit says its not available anymore.
Old Feb 7, 2001 | 12:08 PM
Alright, thanks guys. I thought that the shifter was part of the shift kit like it was all the same thing. I didn't realize that you just replace the stock shifter. Thanks for clearing it up.~ Arnold.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
