Park Ball
Old Feb 6, 2001 | 03:11 PM
84Berlinetta305's Avatar
Park Ball
My 700r4 won't go into park. Actually, it will, but it is just like neutral. When I bought it the guy said it was missing the park ball. I hate using my ebrake and a block of wood to park on hills. How hard is it to fix this problem? Thanks Alot
Evan
Old Feb 6, 2001 | 05:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I think he probably said "park pawl". I'd have to check the book, but I don't think it's too hard to replace.
Old Feb 6, 2001 | 05:38 PM
Oh well, pawl, ball its all the same. What is a pawl anyway, I've never hear that word before. Well, any suggestions would be helpful. Thanks
Old Feb 6, 2001 | 05:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A tooth in a ratchet that engages the gear to keep it from moving.
Old Feb 8, 2001 | 11:20 AM
82z's Avatar
82z
It would require total tranny disassembly to replace the park pawl. It engeges the teeth on the outside or the reaction carrier(?). Basiclly you are out of luck.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 8, 2001 | 08:14 PM
Well dosent that just suck? Well, I better make sure my block of wood is always handy, because I have no desire to take my transmission apart! Would a v-6 tranny fit on the 305?
Old Feb 8, 2001 | 08:51 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
no
Old Feb 8, 2001 | 09:30 PM
Nordbert's Avatar
I think the park pawl can be replaced with
the trans in the car, but first you should
get your trans fluid and filter changed.
While the pan is off, check what is wrong with the park pawl *** 'y. On a TH350 there is
a cup plug holding the park pawl pin in place. The 700-r4 should be made in a similar way.
Old Feb 8, 2001 | 09:45 PM
mikeage2's Avatar
hey your in luck.i just parted a 83 berlinetta 305 v-8 car......it has a th 350 modded to fit in a 700's place.it has about 100 miles sonce total rebuild(required for 700 conversion anyways) and shift kit.i am selling it,the x-member,and what ever else you might need.asking$500 O.B.O make me a offer i need $for a t-5 for the camaro i have now
mike
Old Feb 8, 2001 | 09:46 PM
mikeage2's Avatar
mike
86 camaro:was a v6 car with stick,converting to v-8..NEED A V-8 T-5!!!!!!!!!!email me if you have one!!!
350 cylinders bored .040 over.a little oves 9:1 compression(getting a blower some day when im rich lol)line bored.deck milled a little(was pitted)
trw forged pistons with summit stage 2 polished rods with arp bolts.
194 intake valves,pocket ported,gasket matched,and polished ports,old vette intake with new zinc 650 holley
ase certified for a few years,learned alot though
working on freakin NEONS ,cirruses,tauruses,cobras(wel at least they look nice lol)and intrepids all day makes me drink too much
good job security though
Old Feb 9, 2001 | 12:13 PM
Sorry, but I don't have the money to buy it right now. I might later, but I am not for sure. If I do get it, I will definitely look you up. How much does it cost to get a new park pawl? Would there be something in My haynes manual possibly telling how one would replace the pawl? Thanks for all the Help.
Evan
Old Feb 9, 2001 | 01:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The regular Haynes manual doesn't cover much with the auto trans besides removing it, resetting the TV cable, and changing fluid.
If you find the Haynes "GM Transmission Overhaul" manual (usually by the regular Haynes car manuals at parts stores), that will cover it. It's a great read, and gives a picture-by-picture rebuild of the 700r4. It also shows the TH-350, TH-400, and TH-200-4R being rebuilt.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
RedLeader289
May 28, 2019 01:47 PM
sjorgens
Oct 1, 2015 07:54 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
lewandom
Oct 1, 2015 08:15 AM
