pedals from mechanical clutch same as hydraulic?
Old Dec 3, 2000 | 07:18 PM
mike88RS's Avatar
I got the pedal a ssembly out of an 83 fbird, and it was mechanical. but when i went to hook up the master cylinder(hydraulic) i cant pintit anywhere. are these pedals different?
thanks
mike
Old Dec 4, 2000 | 11:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are extremely different. I have done the swap, and I can assure you there is no way to interchange them.
Old Feb 10, 2001 | 01:21 PM
jarhead82plain's Avatar
RB83L69- I have an 82 Camaro that had a 4 speed in it. Now it has a t5 from an 87. I'm currently using the manual clutch with this trans, but I don't like it. How difficult was the swap to hydraulic? Can you tell me the parts that I will need to get to do this? I think that the newer clutch would be a better way to go (easier on the left leg, to say the least.) How long did it take you to do the conversion? Do the manual and hydraulic clutch use the same hole in the firewall, or do I need to drill a new hole? Thanks for any info you can give me.
Old Feb 10, 2001 | 05:46 PM
IROCracer's Avatar
Different....WAAAAAY different.
As for the second question....to swap from mechanical to hydraulic clutch wouldn't be extremely hard.....you'd obviously need the new pedal assy and the hydraulic assy.
[This message has been edited by IROCracer (edited February 10, 2001).]
Old Feb 10, 2001 | 07:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The swap wasn't that difficult, but at the time I had the engine out which made it easier.
You have to change the bell housing and pedal assembly. You'll need the hydraulics obviously, and the bracket that holds the reservoir next to the brake master cyl. You can get a complete assembly of the reservoir, master cyl, line, and slave cyl at the dealer for a little under $100. It comes pre-filled and bled. That's what I'd recommend you do.
The hole in the firewall where the linkage goes through is very near the right place for the mster cyl. IIRC I had to enlarge it in the downward direction and toward the outside of the car a little, and drill the 2 holes that the U-bolt thing goes through. The pedals are completely different. I'd suggest going to the boneyard and getting the entire assembly out of a car; you'll get the 2 pedals, the bracket they're in, and 2 additional brackets that connect the pedal pivot bolt to the master cyl which are very important. If you get it yourself you'll have the chance to eyeball it and get measuremants and see how everything goes together. Plus, if you take the car apart yourself, you can get all the right hardware and all that, which will make it much easier to get back together.
The hydraulic is defeintely superior to the mech linkage, I'm glad I did the swap. Very much worth it.
ICON Motorsports
Old Feb 11, 2001 | 10:03 AM
Does the slave mount to the bellhousing? My Haynes manual shows a bracket mounted to the bellhousing bolts. Does anyone have a pic of where it actually mounts? I don't like the idea of yanking the trans out to change the bellhousing. If I did that, I'd probably just use the hydraulic throwout bearing (if I can find one).
Old Feb 11, 2001 | 10:22 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It mounts directly to the bell housing. There's a big boss cast off to the side of the BH; it has a large hole for the cyl and 2 small ones for bolts; the cyl mounts into it from the front; there's a large shield type of bracket that wraps around it. So you have to change the BH.
Like I said, go to the junkyard and look at one, and if at all possible take all the parts off of it yourself, that way you'll know exactly what it takes.
I think I might have an extra BH laying around; I'll take a pic and post it if I do.
The throwout bearing is the same in both systems. But there's no choice about the BH, if you want to change it over, it's gotta be replaced.
ICON Motorsports
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Denricci22
Sep 18, 2015 09:02 AM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
