Replaced TV cable, created new problem.
Old Feb 11, 2001 | 02:59 PM
Cosmik Debris's Avatar
Thanks to all those who contributed to my last thread about replacing the TV cable. I finally got it done but this has created a new problem. The TV cable sticks and doesn't return fully. I may have knocked some crap down the TV cable hole in the tranny while I was fiddling about. Can I get access to the spring through the bottom of the tranny (I presume I will have to remove the valve body) and clean it out or do I have to pull the trans out?
Cosmik Debris
Old Feb 11, 2001 | 04:35 PM
The ODB's Avatar
Yes.
Did you remember to lube the inside of the TV cable housing?
good luck
ODB
Old Feb 11, 2001 | 04:49 PM
Actually, I haven't done that yet, do you think it will help? Also lost a bit of trans fluid during the operation but it was only half a cup or so. That couldn't cause a problem could it?
Cosmik Debris
Old Feb 11, 2001 | 05:27 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
I am assuming they gave you the right size T.V. cable. Try removing the T.V. cable from the throttle body and pull on it (gently). While you are pulling it, doing you feel a slight resistant? If not, the cable may have dislodged from the valve body. If so, you can go at it 2 ways to fix the problem. First would be removing the T.V. cable from the tranny and reconnecting it this way. This will depend on how much room you have between your tranny and floor panel. The second would be removing the pan and reconnecting it to the valve body. If I had to do it, I would try the first step. Hope this helps.
Old Feb 11, 2001 | 06:52 PM
I think the cable is still connected OK. I can feel the spring pressure it just binds when it returns. If I wiggle it a bit it will go all the way back down. Can I get at the assembly from the bottom? Do I have to remove the valve body?
Cosmik Debris
Old Feb 11, 2001 | 08:29 PM
Nordbert's Avatar
I would remove the cable at the throttle
body and pull it through the bracket. With
the cable unbolted at its lower end, the
housing should easily slide along the inner cable. If it does, then I would pull on the
inner cable only. If the cable is not pulled back into the transmission by the spring on the TV linkage, I would then get a filter kit
, a case of Dexron III and proceed to remove the transmission pan for a TV valve inspect-
ion.
Old Feb 12, 2001 | 12:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
At the tranny end: Did you insert the tv-cable-linkage-rod into the tv-cable-eyelet properly? It can be made to fit two ways.. with the rod entering thru either side of the eyelet. Maybe you inserted in thru the wrong side, and the rod's at a slight angle, rather then straight up & down?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 12, 2001 | 02:21 PM
That's a good point! I was so relieved to get the cable attached at all. I think the hook was facing out from the tranny.
Cosmik Debris
Frozer!!!
Jan 19, 2024 04:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
