early,sloppy shifts
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
early,sloppy shifts
i recently swapped the rear in my car and have a taller gear ratio than before. since the swap it seems like my trans isnt performing as well as it did before the swap. what can i do to remedy the problem:?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: early,sloppy shifts
The car feeling like it's shifting to quickly now? or alittle sluggish? I had the same issue after I put in my 3.42's. the sonnax tv spring along with a shift kit helps firm things up abit.
Car: 91 rs
Engine: 305tbi
seems like anytime i get on the throttle it wants to shift sooner than before. i have read about the spring, i dont understand where it goes(yes the tv cable but is it on the trans or in the engine bay, anyway you can post a picc?. i do intend on putting in a transgo shift kit over christmas break though.
Here's a pic for you.
It's real easy to install just remember to reset for TV cable afterwards for proper tension.
Car: 91 rs
Engine: 305tbi
k i installed it today. there is a slight noticable difference. but a little short of what i am looking for. what do u mean to reset the cable?
You have to reset the TV cable that you attached the sonnax spring to. It's real easy, here's a quick break down.
You will see a big "D" shaped connector on the throttle bracket that the cable goes through
Press and hold the "D" shaped botton while pulling the cable towards the firewall.
Afterwards, pull the thottle ALL the way open until you here the cable "click". That is the basic way to reset the cable.
Car: 91 Z28
Engine: 5.7 TPI
Transmission: 700R4 Probuilt Hardparts
Axle/Gears: G92 3.23
dont forget to recalibrate the speedo too. I'm in the same boat, and read over the weekend that the vehicle speed sensor supplies input to the ecm for controlling tcc lockup, mainly, and there was also another condition (tps% vs kPa or maybe rpms) but it mainly looked at vss first. gear stacking is for gas mileage... holding rpms is much more fun. that will only affect 4th and O/D, and not 1.2.3. i like the shift kit idea, and then the spring... seems redundant though, to a point. maybe exaclty the opposite and complimentary, I wonder. guess if robertfrank has both, it's all good?
My car doesn't have a VSS so I guess I'm good, BUT....... I still have yet to change out the speedo gears so my readings are off. As far as a redundancy in having bith the shift kit and the spring I can't imagine drivung my car without either. I recently drove a stock 305 tbi car and to me the differance is astounding.
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I have a very similar problem. It shifts into OD at 42 and locks the converter and then shakes pretty harsh. Whats the problem with my car.
Z28/ZR1
Oct 23, 2015 01:04 PM
darwinprice
17
Oct 11, 2015 11:51 PM
