Getting a T56 for my GTA!
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I think I'm buying a '97 SS Camaro T56 in a few weeks. Has about 5k on it. Anything I need to worry about besides floor hole, crossmember, and speedo converter box? TIA!
'91 GTA:
www.fbody.com/members/91WS6GTA
'91 GTA:
Yeah, if you are switching from an automatic to a standard, you need to use some pedals from a hydraulic thirdgen or fourth gen. I just went to the salvage yard and got some manual pedals, but they were from a manual clutch linkage car. These will not work with the 6speed hydraulics.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
1 Post
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Hot Rod Magazine just did that swap, and it showed everything that you needed to do it. it said something about the way the clutch (pushes or pulls)isnt the same between the two generations, and you have to do something to fix it, it was a good article, one of the better ones in hot rod actually, hope this helps. lil jay
Wide Open Till You See God...Then Brake
Car: 2001 Camaro SS
Engine: Almighty LS1
GTA you don't have to do anything with shifter holes, might need a new boot but that might be it... if you have a T5 is basically a direct swap (you can spend about $250 and get a X-member and an adapter so you can use your stock clutch setup)
topteam54
10-06-2015 12:21 AM
