700r4 shift point ?
Old Feb 16, 2001 | 02:50 PM
smithtc's Avatar
700r4 shift point ?
1-2 shift at 4750
2-3 shift at 5250
why different? and how can I adjust?
Gunmetal 89GTA T-Tops L98
Gettin there's all the fun
Best 60 ft: 1.996'
Best 1/8th mile: 9.02 @ 76.5mph with 60' time of 2.14
Mods: air filter, hypertech chip, 3" exhaust
Old Feb 16, 2001 | 10:03 PM
82z's Avatar
82z
You can adjust the shift points with the governor. I don't know why they are different. It may be so the engine doesn't fall below it's power band when it shifts through it's funky ratio spread
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Feb 17, 2001 | 01:45 AM
The ODB's Avatar
remove weights from your governor so that it shifts at a lower rpm.
You should manually shift 1-2 @500 rpms higher than your 2-3 shift in order to maintain the same shift recovery rpm at your torque peak.
ODB
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
