Axle
Old Oct 27, 2008 | 07:36 PM
firebirdman's Avatar
Car: 89 Firebird Formula
Engine: 305 tbi
Axle/Gears: 10 bolt 3.42
?Axle?
I have an 89 pontiac firebird formula. i need a new rear axle. Will an axle from a 98 firebird work on my firebird or does it need to be from a closer year?
Old Oct 27, 2008 | 07:55 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Axle
No, a 98 axle is longer than your 89 axle. I would pull your axle and count the splines. 3rd gens came with 26 or 28 spline axles, I can't recall exactly what year it changed from 26 to 28 spline, but 89 sounds close, maybe 87. Hopefully someone who knows will chime in.
Old Oct 27, 2008 | 07:57 PM
big gear head's Avatar
Re: Axle
A rear end from '82 to '92 will fit. In '87 the ring gear diameter increased 1/8 inch and around '89 or '90 axle splines increased from 26 to 28, but they will all bolt in.
Old Oct 27, 2008 | 08:00 PM
Engine: 305 tbi
Re: Axle
They are 26 spline shafts, 2.73 gears. No posi, so you guys are saying an 98 axle will not bolt in to my 89 firebird?
Old Oct 27, 2008 | 08:05 PM
krisb410's Avatar
Re: Axle
No it won't, didn't you read the posts, the 98 axle is longer than your 89 axles, plus the 98 axle is 28 spline, not 26 spline.
Old Oct 27, 2008 | 08:07 PM
Engine: 305 tbi
Re: Axle
I read your post bud but missed the part that its longer. It doesnt matter if its a 26 or 28 spline tho.
Old Oct 27, 2008 | 08:09 PM
krisb410's Avatar
Re: Axle
Why doesn't spline count matter.
Old Oct 27, 2008 | 08:11 PM
Engine: 305 tbi
Re: Axle
if im putting in a completely different axle it shouldnt matter right?
Old Oct 27, 2008 | 08:13 PM
krisb410's Avatar
Re: Axle
Splines on the axle have to match the carrier.
Old Oct 27, 2008 | 08:17 PM
Engine: 305 tbi
Re: Axle
when you say carrier you mean the differential unit?
Old Oct 27, 2008 | 08:20 PM
krisb410's Avatar
Re: Axle
Yeah, the center part that the axle slides into.
Old Oct 27, 2008 | 08:27 PM
Engine: 305 tbi
Re: Axle
my bad im talking about the rear end not the axle shafts. i have already replaced one axle shaft. I will try to get my terms right in the future
Old Oct 27, 2008 | 08:42 PM
krisb410's Avatar
Re: Axle
Oh OK, just do a "4th gen rear swap" search then. Plenty of info how. I did a 4th gen rear swap. All the info is already here, as I said, just do a search.
Old Oct 27, 2008 | 08:59 PM
Engine: 305 tbi
Re: Axle
okay thanks
Old Oct 27, 2008 | 09:07 PM
krisb410's Avatar
Re: Axle
Here's a good place to start
https://www.thirdgen.org/forums/faq-...-gen-rear.html
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
