AAAAAAAAAAGGGGGGGGHHHHHHHHH MY TRANNY IS DEAD!!!!!!!!!
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
My car sits for a week and I get to drive it on the weekends. I haven't really had many problems with the tranny before. It didn't want to shift into third until I let off of the gas a little, otherwise the engine would just rev. But that was the only problem I had before.
OK, here's what happened. I'm drivin' along, we are on our way to the movies, got two other people in my car. I notice that on the way to the movies, the tranny doesn't always want to put all of the power into the wheels, it just wants to rev a little, then go into the wheels. We get to the first theater, nothing is playing, so I move my TV cable towards the detent button. That really didn't help. When we stop at the second theater 5 minutes away from the other one, I push the TV cable all of the way towards the detent button and turn the throttle all of the way forward and the cable slams into adjustment.
On the way back, it's doin' the same thing, just a little worse. Later on down the road, we cant really go much past 30-35, after that the engine would just rev. I drop off my friends and pull out the TV cable a little. It drives fine for about 3 minutes. I was even able to spin the tires on the gravel and fishtail. I go out onto the streets and the tranny is acting up again. By the time I get back after playing with the TV cable a couple more times, the tranny completely dies, nothing works. No reverse, no drive, no OD, no first, nothing. I actually pushed my car about 150 feet into the parking spot.
I did notice that the fluid was overfilled.
Do you guys think that it I could just change out the fluid and put in the correct amount and it would be OK?
Do you suppose the transmission is completely gone?
Could it have anything to do with the torque converter?
Thanks,
Jesse
85 Z28, 305 TPI A4
pretty stock with MSD and a few other toys
15.2@91mph
http://photos.yahoo.com/j_hougnon
Thanks,
Jesse
85 Z28, 305 TPI A4
15.2@91mph
I heard those aliens out there just go around overfilling trannies at night now because they lost all their publicity... HEE
Doesn't sound good, man. You could drain and change filter to check out what is in the pan and refill but you'll probabaly be crying when you see what happund
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
could be your Torque Converter
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns.
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000.
For Pictures go to
http://members.theglobe.com/RED82TA57L/mycar/
A cool Trans Am site with Message Boards http://www.transamgta.com
RED82TA5.7L
For Pictures go to
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
My '69 Camaro's TH-350 had very near the same problem. At about 40 the engine would just rev with no power getting to the rear wheels.
It turned out to be the torque converter, but it also took out my transmission, too.
Hope yours turns out to be not so bad.
1997 Chevrolet Camaro SS # 379
1992 Pontiac Firebird Formula
1973 Chevrolet Camaro RS/Z28
1969 Chevrolet Camaro SS 350
Short of my family, there was nothing I enjoyed seeing more than the sun shine down on the black #3 car.
I'm old enough to know better, but still too young to care!--Wade Hayes
It sounds like your tranny is cooked. If it was a seized stator clutch you would accelerate fine but have no top speed. Your engine revving over 30 indicates a tranny not torque convertor problem, it would bog otherwise.
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
raymondandretti
Sep 27, 2015 06:43 PM
