Sometimes shifts 2-3
Old Feb 5, 2001 | 12:39 AM
Ratnose86SC's Avatar
Alright a couple days ago i noticed that my tranny wasn't shifting from 2-3. Then the next day it worked fine, but halfway home from work today it stopped working.
Gear selector possibly?, fluids good, and TV cables fine. Ill look into the cable connection, but anyone got any other ideas.
If the trannies trashed im going T-56 anyway.
Old Feb 5, 2001 | 12:48 PM
The ODB's Avatar
sometimes loose material will get into the valvebody. Just remove the valvebody, disassemble and clean everything good. Should fix it up.
If you don't want to clean the valvebody yourself just take it to a tranny shop and let them do the valvebody as a bench-job.
good luck
Old Feb 5, 2001 | 07:04 PM
Yeah i haven't changed the fluid or filter since ive had the car.
Old Feb 20, 2001 | 07:48 PM
How do i get the valve body of?
Also, can i buy a new shift cable assembly from GM?
Old Feb 20, 2001 | 09:01 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
If you are not familiar with transmissions, i highly recomend not to take your valve body off. there are small check ***** that must go back in the same place and if they dont it will mess up the tranny. just my. 02 i made the mistake and tried to put a shift kit in a 700r4. i can do alot of things, but i found out trannys is not one of them.
Wide Open Till You See God...Then Brake
Old Feb 23, 2001 | 03:57 PM
Danny P 86Z28's Avatar
More than likely the problem is the 3-4 clutches are slipping. GM did not put enough cluch plates in the 3-4 clutch pack and this is a weak point. A good rebuilder will add additional clutches in the 3-4 pack to make it stronger.
Old Feb 23, 2001 | 10:54 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
What does the 3-4 clutches have to do with a 2-3 shift?
Old Feb 25, 2001 | 12:04 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Joel...
The fact that the 3-4 clutch is applied in third or fourth gear is what the is probably causing the problem. The 3-4 refers to the gears the clutch is applied in, not the shift that it affects.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand.
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Feb 25, 2001 | 02:06 PM
JoelOl75's Avatar
If you're experienced w/ 700r4s maybe you can help me with a prob...
My trans has 'neutral' lag time between 2-3 shift and my 1-2 shift point increased itself from 4500 to 5800 rpm by itself. It's not the TV cable and when in gear hold strong (no slip) I would rebuild it myself (I did them before) but troubleshooting these things seems difficult. Any help would be appc'd.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
