4l60e question?
Old Nov 4, 2008 | 12:12 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
4l60e question?
i need to know what i need to bolt a 4l60e up to a gen 1 sbc
if anyone can help it would be much apriciated.
Thanks guys, Ted
Old Nov 4, 2008 | 01:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 4l60e question?
You don't need anything to bolt it up.
Old Nov 4, 2008 | 01:23 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: 4l60e question?
isnt there a diff in length of the crank that will push the converter in to far. i think thats what i heard but not sure.
what im trying to do is use a gen 1 sbc w/1piece rear seal
bolted to a 4l60e trans and c5 vette diff !
i know i need a bell housing from a 4th gen. but is there ay kind of spacer or
something i need
Old Nov 5, 2008 | 03:02 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 4l60e question?
attaching it isn't the big deal. controlling it is.
Old Nov 5, 2008 | 03:16 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: 4l60e question?
get a 4l60e from behind an lt1 and it will bolt up just like a 700r4...the ls1 4l60e has a modular bellhousing that can be unbolted from the trans like on a manual tranny but the lt1 trans doesnt its identical to a 700r4 in size and basic shape...just buy a torque convertor for a lt1 car and a flexplate for a sbc/700r4 combo....
you should probably just get a built 700r4 though....
Last edited by igotta355z28; Nov 5, 2008 at 03:18 PM. Reason: Automerged Doublepost
Old Nov 5, 2008 | 07:57 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: 4l60e question?
this is for another project. i cant use the lt1 4l60e or the 700r4.
because this is going to be a mid engine set up! i am using a 4l60e from a c5 corvette and the corvette differential witch bolts in place of the tail housing.
controling it isnt that big of a problem(aftermarket controller).
so will everything bolt up the same converter wise?
this is going in a 68 corvair by the way
Old Nov 5, 2008 | 09:11 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: 4l60e question?
hmm then i dont know what to tell u why dont u just go with an GEN III motor since u know how it bolts up....plus the GEN III is a far superior engine to anything chevy put out before 1997.....
Old Nov 5, 2008 | 09:28 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Re: 4l60e question?
i was thinking of a pull out lq4 but i dont know i could use that money elsewere
Old Nov 5, 2008 | 09:41 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
Re: 4l60e question?
sell the motor u were gonna use i paid 800 for my LQ4....
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
