700r4 help needed
Old Nov 6, 2008 | 02:45 PM
Guest
Guest
Posts: n/a
700r4 help needed
i have a 87 iroc-z 5.7 rebuilt 700r4 my tach is at 2800rpms when im only doing 60mph?? any suggestions?
Old Nov 6, 2008 | 03:00 PM
Stephen's Avatar
Car: 87 GTA
Re: 700r4 help needed
What rear gears do you have? What sized tires are you running?
Old Nov 7, 2008 | 10:34 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
seems like you're not getting overdrive, and if you are, you're both not getting lockup of the torque converter, and you have a very loose torque converter. If you have the 3.27:1 axle, then you again aren't getting the lockup.
Old Nov 7, 2008 | 01:09 PM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Are you sure the tach is correct. It's common for them to fail and when they do they read high. When you floor it what RPM does it shift at? If it's around 5000 - 5500 then the tach is probably working fine.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
TreDeClaw
Aug 14, 2015 06:58 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
