Deep Pan with drain plug for 700R4
Old Mar 5, 2001 | 08:28 PM
chesapeake's Avatar
This link
http://www.b-body.net/Technical/Driv...ans/GMPan.html
quotes the 1999 GM Performance Parts Catalog that says that the 4L60 deep transmission pan will work on a 700R4. I got the pan and filter. The pan looks like it will work, but the filter neck/seal is too large in diameter for the 700R4. Is there a filter that will work ???
I got the pan with part number (24215535) with a drain plug. I want to use the deep pan with plug on a 1988 Suburban 4x4 with 700R4 transmission.
Thanks in advance.
Old Mar 7, 2001 | 12:34 AM
robert1's Avatar
Sure it won't fit? The old seal might be in there, and it is a VERY tight fit so it won't leak. Look in there to make sure. Maybe you have the wrong filter too?
Thornburg
Aug 25, 2015 01:46 AM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
djmarch
Aug 9, 2015 05:27 PM
