Brake lines q's
Old Mar 8, 2001 | 12:29 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Brake lines q's
I will be swapping an 86 drum rear into my 89 drum formula soon. I pretty much have everything except for the brake lines. I heard that they could be different threads on the lines, is that true? If not then i will just reuse the 89 stuff.
Also, i am not quite sure of the year, Here are the only # that are on it: GM N 22522676
Can anyone ID this?
Old Mar 8, 2001 | 12:19 PM
327 firebird's Avatar
86 to 89 will have the same threads. The only difference is in 82-84 had standard fittings while 85 on had metric. One more thing to look for, which I had a problem on is the flare. I'm npot sure what years had what, in the junk yards it seem to be random where some years had both types of flares. There are the double flare which I had(85 firebird) and the single flare lines which seem to be in the 82 - 84 and randomly in newer ones to even include some 4th gen i looked at. Hope this helps... erik
Old Mar 8, 2001 | 12:53 PM
Omega's Avatar
Engine: LS1 / LS3
Thanks for the info, i decided to buy new cylinders and reuse my lines that are on there now. That way i don't have to worry about it.
Old Mar 9, 2001 | 01:14 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
<font face="Verdana, Arial" size="2">Originally posted by 327 firebird:
86 to 89 will have the same threads. The only difference is in 82-84 had standard fittings while 85 on had metric</font>
Nope, you're off by a year. '84+ has metric fittings.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro ZZ4 M5 (V-6 in a former life) -- street beast
'91 Medium Blue Metallic Z28 A4 (UB-HSTRY's old ride) -- currently broken
'99 Navy Blue Metallic Firehawk #120 M6 (99.44% stock) -- daily driver
Reddeath210
Oct 6, 2015 08:20 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Nj1987
Aug 19, 2015 08:26 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
