Gear fluid
It is supposed to be 3.5oz of posi additive along with 1.75 quarts of 80-90W gear oil. Putting more additive will not hurt anything. I put a 7oz tube of additive in mine and put a little less gear oil.
87 Camaro Z28
LB9 305 TPI, Accel cap, rotor, and 8mm wires, K&N filters
1/8 mile: 9.8@69mph
91 Formula
L98 350TPI, Accel 8.8mm wires, Siamese Runners, Edelbrock Headers, Edelbrock 3" Cat-Back, Airfoil, K&N Cone Air Filter, AFPR, Shift-kit, Mallory Promaster Coil, Nitrous Works Wet Kit 75hp
1/8 mile: 7.9@86mph
87 Camaro Z28
1/8 mile: 9.8@69mph
91 Formula
1/8 mile: 7.9@86mph
Transmission: 4L80E/4L80E
Assuming you haven't done this yet: It takes just under 2 qts.
Get ahold of some AMSOIL Series 2000 75w90 gear lube. It has the friction modifier built into it - you don't need the extra stuff. And, you'll get the benefit of the synthetic base.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Yes, the additive really works IF you're using a dinosaur juice-based lube. But, as I said, use the synthetic and you don't have to worry about the additive.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You should ALWAYS use the GM posi-additive when you change the fluid in your posi rear end. Unless you use synthetic fluid, like was said above.
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Even with synthetic gear oil I use the GM additif,it won't hurt at all!!
UltRoadWarrior9
Sep 2, 2015 08:24 PM
