2.8 tranny with a 4.3??
I am wondering if I can run my tranny with a 4.3 v-6... Its an 4l60E or something like that. Is there an adapter plate or something similar i can buy?? or am i outta luck??
I have a th350 and a th400(olds bellhousing)
But if i go with the th350 I will need to change my drive shaft and cross member and tourqe arms right?? Im really lost with all this swap stuff so if anyone can help me id really appreciate it
JJ
JJ
yes u can use that trans with a 4.3 u will need a v8 bellhousing and a 4.3 clutch set, i will get u the part numbers if u want, also the 4.3 uses an 11 inch clutch so it will be nice.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
