max tire size
Old Nov 19, 2008 | 09:03 AM
transam360's Avatar
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
max tire size
dident know where to put this thread under but here goes i am wanting to put a 29.5x10x15 on my firebird will they fit
Old Nov 19, 2008 | 10:56 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: max tire size
You'll probably have issues with the diameter. I had 28x12.5x15's on mine once, and those needed some work for the diameter. The tire by itself wasn't too tall, but the ballooning was. You could probably fit them though with some work.
Old Nov 19, 2008 | 11:12 AM
transam360's Avatar
Re: max tire size
what all do you think i have to do just hammer in the inner fenderwell or is there issues with it hitting the fender on the outside
Old Nov 19, 2008 | 11:29 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: max tire size
I have 325/50/15s on mine now, and those measure 27.5x13x15. I was looking into using a set of 315/60/15s that should be about 29.5x13x15. It would take either some HEAVY beating or some cutting/welding on the front of the inner fenders and rolling the lip on the top of the fenders. I think the diameter will fit, but somehow my axle isn't centered in the wheel well. Using a non-radial type of tire requires more clearances, but you should have the same game plan.
Old Nov 19, 2008 | 02:34 PM
transam360's Avatar
Re: max tire size
yea if i have a problem with height i could just lift the car a bit with the coilovers and if the axle is'nt centered i can adjust the ladderbars but is there any supports in the front of the wheel well i got to worry about when i either hammer or weld it
Old Nov 19, 2008 | 02:47 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: max tire size
my QTP's measure out 28.5x11.50 (about 28.5x10 in slicks).. and there is definitely room for another inch.. i only hammered a bit..
Old Nov 23, 2008 | 03:56 AM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: max tire size
i have 295 50 15s in the rear on my camaro i just put air shocks to make clearance and it works. hope this helps.
Old Nov 23, 2008 | 11:30 AM
transam360's Avatar
Re: max tire size
just put the tires on today they fit good the top of the tire lines up with the top of the fender and with the coil overs i have i moved it so there is about 1 1/2" around the tire and wheel well
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
