will a 4.3 t-5 work?
Old Mar 15, 2001 | 10:47 AM
nestz28's Avatar
Did GM ever use the T-5 with a 4.3? I need a spare t-5 while I look for a better tranny and since the 4.3 has the same bolt pattern as the small block I was thinking I could use one of those. Does anybody know if it is like the other t-5s used with the v6's or is it stronger? Thanks.
'84 Z28 LG4 T-5
'92 Z28 wheels
153,000 miles
Front& rear suspension rebuild using MOOG parts
350 and WC coming in summer 2001
'70 nova 307, th350, all stock, 40,000 mi almost like new
Old Mar 15, 2001 | 04:16 PM
Fastcamaro87's Avatar
yes they did put a t-5 behind a 4.3 however it uses an 11 inch 14 splne clutch . so you would probably need the flywheel, clutch set and the trans , everything else should work fine.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
