92rs diff info for a 3.73 posi swap
Old Mar 16, 2001 | 10:41 AM
thadd47's Avatar
i'm pretty sure the gear ratio on the 92rs is 3.42, but i don't know the ring size.(i'd rather not take the cover off again and measure if someone knows) i /have a 7-5/8 3.73 ring and pinion with a GM posi carrier to put in. i'm not sure on the 2-3 series info. will this swap work? if they are the same size would the swap be as simple as retaining the same shims and slipping the new unit in?
thadd47
Old Mar 16, 2001 | 10:42 AM
thadd47's Avatar
oh yeah, the 3.73 and carrier is a 10 bolt
thadd47
Old Mar 16, 2001 | 11:22 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I have a 92 RS as well, and it has a 3.08 gear ratio, which I think is a 2-series carrier. If you have the new diff and gears you will be fine, since your new carrier is more than likely a 3-series which is required for the 3.73 gears. good luck
Old Mar 16, 2001 | 01:30 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the ring gear and carrier were already in a diff together before, and you're putting them both into your rear, it doesn't matter if they're 2- or 3-series, or what your current setup is (which is 3-series, if factory, by the way).
You should have it set up by someone who has the proper special tools and knows what they're doing.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Mar 16, 2001 | 01:36 PM
thadd47's Avatar
i talked to a guy at summit and he said that if you convert from a 2-series to a 3-series(or vice versa-can't recall) that you will need an adapter piece because one is longer(thicker) than the other. any more info?
thadd47
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
