trans shift kit responses
Old Mar 10, 2001 | 10:53 AM
410GEARRATIO's Avatar
OK guys i need to know what would happen if i put the trans go shift kit in my transmisson with 130K miles on it. Will it kill it faster or will it prolong its life, ive been through
your message boards for a couple of days and
keep getting mixed responses on this issue.
jon
mods:14x3 open element air filter,
underdrive pulleys, hypertech chip stage 2,
160 thermo, 160 switch, b&m oil cooler,
getted cat and 4:10 gears.
Old Mar 10, 2001 | 12:33 PM
tranny doctor's Avatar
Don't install shift kit with those miles and if you do use a difference brand of shift kit. F.C.
Old Mar 10, 2001 | 05:18 PM
So then it will wear my transmisson out quicker???
thanks
jon
Old Mar 13, 2001 | 11:27 AM
With those kind of miles you might get another 100,000 miles or maybe 100 miles. Drop your pan and see what pan looks like.
Old Mar 13, 2001 | 05:50 PM
precision350's Avatar
Shift kits are good and bad. On the good side they firm up the shifts saving the clutchs from wear, on the bad side the firm shifts put strain on the weak links. Its kind of like when you close your car door nice and easy as opposed to slamming the door.
92 Camaro Z28
350 TPI
Dart Iron Eagle heads
10.5:1 cr
Lunati L54779 cam
52mm throttle body
Ported plenum
Home made AFPR ($2)
1 5/8 shorty headers
Ram air
255 lph Holley fuel pump
2.5 inch TRUE DUAL exhaust (no cats)
Flowmaster mufflers
4.10 gears
700R4 w/2000 stall
100HP nitrous
Best time before any of these mods:
15.1 @ 91.9
Best time after mods:
12.60 @ 108.3
That is at high alt.
5600 feet Morrison, Colorado Bandimere Speedway
Old Mar 14, 2001 | 07:05 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Actually most shift kits are a joke. They give you a little pin to block the line bias. A drill bit to enlarge a hole, a stiffer boost spring and spacers to disable the accumulators. For money it's better to do the servo, .5 boost valve, and flip your accumulator pistons (so they are next to the seperator plate and the spring goes in first). Get the drill bit(s) yourself. It comes out at about the same price so it's like getting a servo and .5 boost valve for free.
Better than 2 little pieces of tubing!!!
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 15, 2001 | 04:37 PM
Pro Built Automatics's Avatar
The Trans-Go does not block the 1-2 accumulator. It makes quite a few changes in the valve body, such as a new 3-2 downshift valve (along with other modifications) that releases the 3-4 clutch pack quicker. If you install the complete kit it will give you new forward & 3-4 release springs. This will prevent accidental 3-4 clutch apply when taking the engine over 5,000 rpm in first or second gear. It also helps in releasing the 3-4 clutch quicker The Corvette servo helps the firmness of the 1-2 & 2-3 shift. The larger boost valves help with holding power & somewhat the firmnest in the shift. Trans-Go does not block the line bias valve they work with it by changing the spring pressure in relation to which main boost valve (.421-.471-.500) you are using.
The parts I add to the Trans-Go kit go even further in addressing the 1-2 accumulators. When setup correctly you can have a nice part throttle 1-2 shift that gets progressively firmer with more throttle. Trans-go offers this information to those who will call & ask for it. As I stated I offer this info too. Call me at 8007763288 Mon-Sat 10-6 PST.
Glad Too Help!!!
Old Mar 15, 2001 | 07:34 PM
JoelOl75's Avatar
I said 'most'... and yours actually seems like a well put together kit. I was mostly referring to B&M which isn't worth the large cardboard box it comes in. Your kit combined with the corvette servo sounds like an excellent upgrade. Does it come with a modified seperator plate or drill bits to open the apply and release holes?
The info I got on this is .110" on the 1/2 and 3/4 apply and .078" on the 3/4 release and .055" on TV balance. Does this sound about right? I heard somebody throwing different #'s and heard if you go to big on the 3/4 release you can have a cut loose or slide bump on the 4-3 shift.
'88 Camaro RS 2.8L
Old Mar 16, 2001 | 07:11 AM
There are two different 700R4 kits. First if you are going to use the performance shift kit then the hole sizes are 2nd apply .086 if you are using the 12" torque converter or .096 if a 10" torque converter. Third apply .155-.187. Fourth apply .187-.203. The 3-2 downshift .155-.187. The 2nd gear release .110-.116. The rest of the kit goes along with these hole sizes to achieve the desired results. The hole sizes you are mentioning seems to go with the 2004R. Hope this helps!
Old Mar 16, 2001 | 08:56 AM
fast89's Avatar
You guys are confusing me a little. Should I go out and buy a Trans-Go shift kit or should I buy some other kit that offers more parts like the servo?? Need direction, Thanks..
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires
Old Mar 17, 2001 | 03:49 AM
JoelOl75's Avatar
Thanks for the sizes... I wasn't really sure because I got all my stuff mixed together.
Old Mar 18, 2001 | 03:23 PM
The Trans-Go Performance Shift kit is available two ways, (1) with a video, large boost valves, and Corvette servo (2) or without the video. Hope this helps!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
