diff swap/brake lines
Old Mar 17, 2001 | 10:09 AM
Sals82Z28's Avatar
I'm hoping someone can help me out with this. I have an 82 Z28 that has a 10bolt drum rear. I want to put on a disc rear then swap the gears. After reading so many different stories, I thought of a question. Since in 82 the threads on the brake lines are different than lets say 84-85 (metric) will I come into a problem in swapping a 90 rear? If I get the 90 rear do I need to go buy 82 calipers so the threads will match from the calipers to that "T" brake fitting that bolts to the rear? Also do I need to change my master/booster for adding disc?
Thanks.
Old Mar 17, 2001 | 05:15 PM
ede's Avatar
ede
if you have to you ought to be able to swap clyinders and that would fix you thread problem, if not you could buy a flare tool and make you own bastard line with differant fitting on each end, or have someone make it for you.
ICON Motorsports
1st & 3rd
Old Mar 19, 2001 | 02:43 PM
Sals82Z28's Avatar
EDE, thanks bud for the advice, now how about the master/booster for the brakes? Does this need to be changed to or can I buy a proportioning valve from Summit or Jegs and use that instead? Or does this not have to be changed?
junior419
Apr 7, 2025 11:35 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
carattini
Sep 10, 2015 07:46 AM
TBRays98
Sep 6, 2015 05:05 PM
rudolphschenker
Sep 4, 2015 02:41 AM
