BW 9 Bolt Axle Vent
Old Nov 29, 2008 | 08:36 AM
kit-ss's Avatar
Car: 91 TA
Engine: 355 FR Stealth Ram
Axle/Gears: BW 9 BOLT 3.27
BW 9 Bolt Axle Vent
Anyone know where to get an axle vent for the BW 9 bolt?
Old Nov 29, 2008 | 08:42 AM
big gear head's Avatar
Re: BW 9 Bolt Axle Vent
I'll have to check, but I'm pretty sure that they are the same as the vents used on the 8.8 Mustang rear ends.
Old Nov 29, 2008 | 08:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Guessing, I'd say the 9- and 10-bolt have the same vent. GM p/n 1236317. Good number on GMPartsDirect.\
JamesC
kit-ss's Avatar
Car: 91 TA
Thanks! I just googled it and it looks right on.
JamesC
I have a 10 bolt in the garage and it looks like a press in type where as the 9 has a hex fitting.
Old Nov 29, 2008 | 08:59 AM
The 10 bolt has a press in plastic vent. The 9 bolt has a screw in steel vent.
Old Nov 29, 2008 | 09:11 AM
JamesC's Avatar
Interesting. I'm curious. Any reason why this is so?
JamesC
Old Nov 29, 2008 | 01:25 PM
The 9 bolt is built in Australia by Borg Warner. The 10 bolt is built here.
Old Nov 29, 2008 | 03:38 PM
JamesC's Avatar
I understand that, but I'm still curious about the 'why?' Is there something about the 9-bolt that makes the difference necessary?
JamesC
Old Nov 29, 2008 | 03:46 PM
No, it's just how Borg Warner builds them. The vent is in the axle tube, the way Ford does it. GM puts the vent in the center casting instead of the axle tube. Putting it in the casting actually makes it stronger. When you drill a hole in the axle tube it makes the tube weaker in that spot. I have seen 9 inch Ford axle tubes fail because of this. Many people will weld the hole shut in a 9 inch and relocate the vent.
Old Nov 29, 2008 | 09:53 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Im parting out my 9 bolt as we speak, if its something i can pull off of my rear end your more than welcome to it. Seeing as there is no aftermarket for the 9 bolt it might be your best bet. But from the sounds of it it im not too sure if i can even take mine off.
Old Nov 30, 2008 | 02:14 PM
I checked the vents and the 9 bolt uses the same vent as the 8.8 Mustang rear end. They are exactly the same.
Old Dec 1, 2008 | 09:08 AM
kit-ss's Avatar
Car: 91 TA
Do you think one of the JEGS screw in vents will fit? they come in two sizes.
1/8 NPT and 1/4 NPT.
Also it seems like only one place sells the Mustang 8.8 vent (latemodelrestoration). Any ideas?
Old Dec 1, 2008 | 12:01 PM
I have a new Mustang vent on the shelf. Ford sells them. I can sell you the one that I have or give you the part number.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
TBRays98
Sep 6, 2015 05:05 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
