need help removing rear axle!!please help.
Old Mar 19, 2001 | 08:37 PM
jm91rs's Avatar
my dad is trying to remove the rear driver's side axle of my brothers 4th gen ta. I am not sure if they are similar to a 3rd gen or not, but we need help. We cannot get the pin out (a huge silver pin) it will not come out for anything. Is there a trick? Please help quick because we just bought the car and we are dying to get it on the road.
[This message has been edited by jm91rs (edited March 19, 2001).]
Old Mar 19, 2001 | 08:48 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
it should be very similar to our 3rd gen the big pin should have a bolt holding it in then after removing the retaining bolt. rotate the diff so that the retaing hole is a way from you the take a punch and tap the pin out a little then turn the diff back toward you and you can use the hole in the large pin to pull it out.
Old Mar 19, 2001 | 09:11 PM
jm91rs's Avatar
I'll try, but i am pretty much doing all of that. I will keep trying though..Any other tips.
91 rs, convertible, K&N, Edelbrock open element cleaner, 3.73, B&M mega-shifter, goodmark cowl-induction hood,tinted windows
Old Mar 19, 2001 | 09:42 PM
jm91rs's Avatar
Do you have to beat the hell outta that pin? That pin is damn near impossible to get out of there. I am having no luck? any tips?
Old Mar 20, 2001 | 12:48 AM
jm91rs's Avatar
Anyone else?
Old Mar 20, 2001 | 02:08 AM
Mo's Avatar
Mo
Be careful, when you hit that pin if you are hiiting it into the housing. I was pulling a differential apart at a pick and pull one time and the pin wasa real stuck, anyway I hit it hard and it went too far. Couldn't rotate the differential anymore...good thing it was at p&p.
try sliding a small screw driver or something through the bolt hole and pull it out towards you.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Mar 20, 2001 | 08:45 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Did the whole bolt come out or did it leave the non threaded part in the housing??
These break and you must remove the broken peice or you will beat on it all day and nothing will happen.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Mar 20, 2001 | 04:58 PM
jm91rs's Avatar
whole bolt came out....but that damn pin will not budge..anyone else?
Old Mar 20, 2001 | 05:15 PM
jm91rs's Avatar
Ok, it is possible that the bolt had been broken off. It does look slightly rounded on the end, like it may be broken. My question now is how far does that bolt go through the pin? I might have part of the bolt in there still. How do i go about getting this bolt out? And one more question, will the pin slide out either way?
Old Mar 20, 2001 | 06:16 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The pin comes out either way. It will (should slide out easily) It sounds like you broke the lock bolt. In that case you will probably have to take the carrier out and work on it on a bench.
Good luck
  • 89 Formula 305 WS6
    SFC's,
    LCA's,
    Air foil
    Flowmaster cat back
    Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
  • 90 Eagle Talon 2.0
    (winter beater)
    Mods? HA! its a rice burner!
Old Mar 20, 2001 | 06:41 PM
Engine: ls1, LB9
how will he get it out if the pin is still in there?
Do the threads on the bolt stop and the rest have a lowered smoth part? if so you may be able to us some picks to help the rest out
Old Mar 20, 2001 | 06:56 PM
jm91rs's Avatar
I am trying to use a magnet to get it out, but i am not having any luck. It looks like maybe half or more of the non-threaded part is stuck in there. We cannot figure out how to get it out.
Old Mar 20, 2001 | 07:38 PM
jm91rs's Avatar
any one else had this problem? We are stuck, it sucks when you buy a car and you can't drive it. Please help
Old Mar 21, 2001 | 11:05 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
I've used 2 dental picks and VERY carefully spun it out.
The bolt usually breaks and leaves 1 thread left and the unthreaded part in the case.
Whatever you do, do not damage the threads on the carrier, it will be impossible to get the pin out if the threads are boogered up.
I can usually get them out in a couple of minutes. (I've done at least a dozen of them )
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
[This message has been edited by Engineboy (edited March 21, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
3rdgenparts
Aug 8, 2015 07:09 PM
