4:11 gears???
Old Dec 2, 2008 | 07:09 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
4:11 gears???
My car has the stock 3:27 I believe gear ratio Correct me if im wrong but anyway its stock. My dad says my car need new gears and says 4:11 would be good. Anyway, do you know where I can get new gears and what ratio is best for a street 1/4. Its an auto.
Old Dec 2, 2008 | 07:14 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Re: 4:11 gears???
If you have TPI you may have trouble hooking up. Stall converter swap as well I hope?
Old Dec 2, 2008 | 07:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 4:11 gears???
also, if you have stock TPI, the cars powerband is not very large, with 4:11's your car will run out of breath really quick and your times will suffer.
Old Dec 2, 2008 | 08:04 PM
Transmission: 700r
Re: 4:11 gears???
What gears should I put in it then. I am putting some bolt ons down the line.
Old Dec 2, 2008 | 09:01 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: 4:11 gears???
While i dont have a TPI i have always liked my 3.45/42's. Never driven my car without them. Good gas mileage and good acceleration also, 4.11's are not good street gears, the highest i would go is 3.73.
Old Dec 2, 2008 | 10:20 PM
Transmission: 700r
Re: 4:11 gears???
where would I find those gears and price.
Old Dec 3, 2008 | 12:31 AM
Saber's Avatar
Re: 4:11 gears???
Pretty much anyone sells gears for the 10 bolt, summit is one i know off hand. 9 bolt gears are hard to come by though and since you have 3.27's im guessing you have a 9 bolt, I just sold off my set of 3.45 9 bolt gears, look in the classifieds they pop up every once and awhile. 9bolt.com sells pretty much everything but he is ridiculously expensive.
Old Dec 3, 2008 | 10:39 AM
Shagwell's Avatar
Car: projects.......
Re: 4:11 gears???
With a motor that peaks out around 45-4800 rpm, you definitely don't want 4.11's. - Yes, if it is a 3.27, not a 3.23, then it is a 9-bolt(count the bolts on the cover and you'll know for sure). If it is a 9-bolt, then you're gonna have to do some searching to find a gear and/or pay some pretty good $. All that stuff is made over in Australia.
I agree on a a 3.42/3.45(10-bolt/9-bolt, respectively). Good gear to get you a some more excelleration w/o putting you out of the engine's powerband or costing you a bunch of mpg.
Old Dec 3, 2008 | 02:49 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 4:11 gears???
http://www.ringpinion.com/PartsList....b-Differential
for 3.73:1 ring and pinion for $177, for 7.75" 9-bolt, from Randy's, new
Old Dec 4, 2008 | 02:55 PM
jjlabinski's Avatar
Engine: shinny 350
Re: 4:11 gears???
3.73 is highest you want to go with using stock converter.
Old Dec 5, 2008 | 08:21 AM
Shagwell's Avatar
Re: 4:11 gears???
good to see they've gotten reasonable since I played with a 9-bolt.
Old Dec 5, 2008 | 12:03 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 4:11 gears???
There's nothing inherently wrong with using a stock converter with gears over 3.73:1.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
