How much time to change speedo gears in a T5?
Old Mar 24, 2001 | 11:44 AM
leirch's Avatar
Ok, here is the situation. I am wanting to get the car running before this coming weekend of the 30th. I finally got the body all back together from the body shop, got it running decent now. I just need to correct the speedo due to the 3.73.. I finally have all of the gears and what not.
How long/hard would it be to put those gears in? Less than one night?
What all is involved? And do you HAVE to pull the tranny out?
Thanks,
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Mar 24, 2001 | 02:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If you have to change the drive gear, then yes, you will have to pull the trans out. You have to take the extension housing off, which I doubt would be possible with the trans still in the car. Even if it is possible, it would still certainly be faster with it out.
If the drive gear is OK and all you need to do is swap the driven gear, it will take you longer to jack up and support the car than it will take to do the swap, even if you have a lift.
ICON Motorsports
Jorlain
Aug 24, 2022 05:11 PM
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
beachrodder
Aug 7, 2015 04:27 PM
