700r4 manual lock up?
Old Dec 5, 2008 | 04:49 PM
nova2only's Avatar
i have a 700r4 out of a 1984 corvette and there are three wires coming out of the square hook up. a red, orange with black stripe, and blue. i think if i hook the orange to a ground then the red one to a toggle switch that goes to the battery then hook the blue one up to the brake lights that i can manualy lock it. would this work? and if not how would i hook up the wires? thanks, Matt.
Old Dec 5, 2008 | 05:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700r4 manual lock up?
You need power on pin A and ground on pin D.
Old Dec 5, 2008 | 06:10 PM
nova2only's Avatar
pin A would be the red wire? what about the blue wire?
Old Dec 5, 2008 | 06:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll have to look at the connectors to see which pin is which.
Old Dec 5, 2008 | 07:26 PM
nova2only's Avatar
ok i looked at it and red is A and orange is D. Blue is B where does that one hook too.
Old Dec 5, 2008 | 07:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
B will be some sort of signal to the ECM.
Old Dec 5, 2008 | 08:53 PM
nova2only's Avatar
so i hook the A pin to a toggle switch that goes to the battery then hook the D pin to a ground and im done?
Old Dec 6, 2008 | 10:11 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That would be one way to do it.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
TheTraut88
Sep 7, 2015 05:22 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
