tranny help
Old Dec 12, 2008 | 04:11 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
tranny help
hey everyone im getting a 350 tpi swapped to a carb and puting it in my car it was with a T/5 and i have a 700-R4 i was wondering how i can get the tranny lock up to work i know one was is with a switch and flick it up when i want it locked but what speeds is it usually locked up and when i slow down do i unlock it??
thanks
Old Dec 13, 2008 | 06:01 AM
kcb37's Avatar
Re: tranny help
Summit or jegs should have the lockup kit.
Don't know if you have to manually switch all of them or not.
It shouldn't lock until it's in 3 or 4 gear.
Old Dec 17, 2008 | 03:16 AM
darkride86T/A's Avatar
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
Re: tranny help
Check with Summit or Jeg's. TCI and Painless Wiring both make lock up kits for non ECM controlled 700R4s. Also search through some of the old threads, because it's been discussed before, and you could save money by making your own kit. The prices for these lock-up kits range from $80 to $130.
Old Dec 19, 2008 | 12:10 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: tranny help
the 700r4 most likely has a normally open(or NO) 4th switch, and a two wire tcc. if this is the case you can run the black wire from the tcc sol to the 4th switch and the red to a th400 1 wire connector. Just run a power through a toggle with a brake switch interrupt and you can lock any time the trans is in 4th gear if you like. The th400 connector approx. $5.. and there should be enough wire inside the trans to make the splices. This is cheap eh? No matter how hard you try it won't lock in any other gear because the 4th switch provides a ground to the circuit only in 4th- and all you need to do is add the power when it is in 4th. Make sense?
Old Dec 20, 2008 | 01:07 PM
Re: tranny help
Exactly, just what Ed o said. I believe only the '83-84 700's were a wired a little different.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
