Differences in rpm between 84 700R4 & 91 700R4
Old Mar 31, 2001 | 12:59 AM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
I'll try to keep it short; for example, I drive at 70mph in my '84 TA, tach says about 2,400 rpm. If I drive at 70mph in my '91 bird, the tach says only about 1,800. Is it rear gearing that determines this, or something with the tranny? Maybe both? I'm (almost)clueless when it comes to this stuff.
DR Stevens
1984 Trans Am 305HO L69
sucks gas, hauls ***
1991 Firebird 305 LO3
for days when I need a/c
Old Mar 31, 2001 | 07:29 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its in the rearend. The internals between the two transmissions are almost identical (as far as gearing anyway). It almost sounds like the '91 may have 2.73s and the '84 probably has 3.42 or 3.73.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
