Advantages to posi over limited slip
Old Mar 26, 2001 | 07:51 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
What are the advantages to posi over limited slip? Is the posi car easier to oversteer than the limited slip car?
Just wondering as I'm thinking of replacing my rear drums with discs and don't know whether to get a posi unit or just go for an aftermarket set-up.
Thanks for the help
Robert
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
"I like to think of her as Arnold Schwartzeneger in a dinner suit" RMK
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods due in March:
K&Ns
RAM Air
Air foil
AFPR
Hoping to get a couple of tenths with that lot
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph (about 98mph corrected)run with no gas and in the freezing cold
Old Mar 26, 2001 | 08:02 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
This seems like a common source of confusion. As far as I know "posi-trac" is just a trade name (like "traction-loc") for a limited slip differential. Are you asking about the differences between a stock open differential (commonly known as a one legger) and a factory type limited slip diff. or are you talking about the difference between a factory type limited slip and a "spool" where the two axles are physically connected together resulting in a locked differential (not really a differential at all)?
for street use a "limited slip" differential is the way to go.
my $.02
later
Clem
Old Mar 27, 2001 | 05:25 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
If I floor it at the moment only one wheel will spin.
Old Mar 27, 2001 | 05:39 PM
Ovrclck350's Avatar
You have an open differential then, although from what i hear, sometimes both will spin in extremely slippy conditions.
Limited slip is what you're referring to as Posi-Track, and it's where "both tires spin".
Easy check. raise the back end of your car and spin a wheel. If the other goes the same way Limited Slip. Opposite way, Open.
Old Mar 28, 2001 | 12:42 AM
Bort62's Avatar
Trac-Loc, thats ford speak!
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Mar 29, 2001 | 06:16 PM
ede's Avatar
ede
main advantage of posi over limited slip is it's easier to spell, other than that it's the same thing
ICON Motorsports
1st & 3rd
Old Mar 29, 2001 | 06:40 PM
Cliff92Z's Avatar
Car: 1992 Z28
LOL
Old Mar 29, 2001 | 08:32 PM
Pro Built Automatics's Avatar
They both do the same thing. There are differences on how they work, some use clutches and others you cones to achieve a limited slip condition.
Hope this helps!
Old Mar 29, 2001 | 09:04 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
<font face="Verdana, Arial" size="2">Originally posted by Bort62:
</font>
Yep, that's my point exactly they're all just trade names drummed up by our beloved oem's.
Clem
BIG THREE:
derrrr.......
(I work for the best of them)
Old Mar 31, 2001 | 03:45 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Thanks for the help guys
Robert
Old Mar 31, 2001 | 04:58 PM
FlashGTA
Guest
Posts: n/a
There is another type of rear-end known as a Detroit Locker. It works on a ratcheting principle and is by far the best street rear-end made. The problem is they are loud and clunky when going around corners, but if you can handle it then they give the best handling and the best acceleration of any type of rear-end. A lot of people just call these locking rear-ends.
Old Mar 31, 2001 | 07:20 PM
84FTA's Avatar
Lockers are much different, lockers usually don't use clutches and they offer no slippage (opposed to limited slip) which is why they are noisy on the corner. They are infamous for breaking axles before they break unlike limited-slip units that will wear out and slip over time
1984 WS6 Hardtop Trans Am
Former L69 Car under restoration
1984 T-top Trans Am
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Apr 1, 2001 | 01:28 AM
FlashGTA
Guest
Posts: n/a
There are no lockers made that use clutches. It is all mechanical just like I said it's a ratcheting mechanism. They don't slip, they ratchet but it has the same effect, letting the inside wheel turn slower than the outside wheel when going around a corner, and sending power to both wheels. Yes, they are noisy as I said and clunky as I said, but nothing is better than a locker other than a spool for fast 1/4 mile times. They also don't wear out like a limited slip does.
KO1
16
Oct 15, 2015 05:00 PM
racereese
Oct 3, 2015 03:46 PM
