Limited slip diff or Locker
Old Mar 24, 2001 | 10:00 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Which is better? Opinions and real life experience appreciated
Old Mar 25, 2001 | 07:49 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Pukka,
In my opinion, a locker is for the track only or 4 wheel drive off road, they have no place on the street. A limited slip(posi) is what I highly recommend for street performance. I have the Auburn pro in mine, VERY nice and heavy duty as compared to stock, I doubt this thing will brake.
You may want to stop by the house since you are in Savannah and we can talk more, I did have a locker once but didn't drive it, returned it after more research(powertrax).
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old Mar 25, 2001 | 08:49 AM
82camaro's Avatar
Car: 82 camaro SC
Powertrax is just as streetable as limited slip. You should have driven it. It's not a 'normal' locker that most people think of. The 'seasoned' mechanics tried to talk me out of the powertrax many times. However, after then drove my 82 with the locker, they changed their minds quickly. Don't talk **** about it until you drive it please. If you want to keep your current gears the powertrax is great. You don't have to remove the gears or carrier so you won't have to have the gears set-up by a pro. I got my powertrax when they first came out (5 or so years ago I think), and haven't had any trouble.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 25, 2001 | 09:51 AM
Pukka's Avatar
I've got some extra cash and was looking into replacing my stock diff with either one of these. SLP has the H/D Zexel-Torsen diff on sale for $300...the Powertrax performance locker goes for about $370. Any more opinions would be greatly appreciated...but please respect everyone else's thoughts...not trying to start a flame war.
JM, send me an email with your phone #...if I can get a day where both my job and my wife can leave me alone I'll holler at you.
Old Mar 25, 2001 | 11:41 AM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
You say that the powertrax is great if you want to keep your current gears. Does that mean if you want to get different gears you can't use the powertrax?
LONG LIVE THE MUSCLE CAR!!!!! MAY ITS REIGN NEVER END
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
Old Mar 25, 2001 | 11:55 AM
robert1's Avatar
No, you can still use PowerTrax, but it will be more money. If you're going to change gears, you might as well get a different, cheaper, differential. SLP sells the Zexel take-offs for $99. I'm deciding that same question now. Since I'mchanging gears, I'm going to get a cheaper diff, and take it all out anyway.
Old Mar 25, 2001 | 01:33 PM
82camaro's Avatar
Car: 82 camaro SC
The powertrax swap ends up more money when compared to a $99 slp swap if you already have 28 spline axles and want different gears. slp carrier requires 28 spline. powertrax still has better traction though.
82camaro
[This message has been edited by 82camaro (edited March 25, 2001).]
Old Mar 25, 2001 | 06:28 PM
Cliff92Z's Avatar
Car: 1992 Z28
I ordered the HD Torsen from SLP and gonna have em put in next week. it does require 28 splines though. it doesn't have any clutches either but it still works like a limited slip. i'm getting 3.73s put in also. like the others said, if you're gonna be running only at the track...then go with a locker, otherwise get a limited slip so you can turn corners easier.
Old Mar 25, 2001 | 09:39 PM
Engine: 4.0L
National Drivetrain sells the Auburn Pro for $345, any spline, any year. The basic Auburn is even under $300.
I didn't do a gear swap because I had a 3.73 axle laying around. It was an open rear.
86 Camaro Sport
My Camaro Project
Old Mar 25, 2001 | 10:40 PM
82camaro's Avatar
Car: 82 camaro SC
The powertrax turns corners just fine. It's not a track only item. Cliff92Z, is this your real-world experience with a powertrax in a third-gen, or are you thinking that all lockers are a track only item? It's not a typical locker. The people at powertrax should have thought up a different name to describe it. 'Locker' brings to mind harsh, loud cornering and not streetable. It's none of those. Ask some people that have a powertrax how they corner.
82camaro
Old Mar 29, 2001 | 11:28 AM
VortecZ's Avatar
Car: Camaros
Is the Powertrax you are talking about the "Lock-Right" model or the "No slip traction system" model? I'm thinking about getting the Lock-Right because it is over 100 bucks cheaper, but the No-Slip sounds a lot better for cars.
Old Apr 1, 2001 | 05:44 PM
82camaro's Avatar
Car: 82 camaro SC
I have the lock-right. The 'no-slip' is a new design powertrax came up with.
82camaro
Old Apr 1, 2001 | 07:10 PM
buddman91rs's Avatar
whats the DIFF. (hahahaha ) between a locker or a limited slip? i thought they are the same...
1991 RS LO3
mods: 14" chrome air cleaner, straight-piped after cat exhaust with one chrome dual tip on the left side.
future mods: headers, removing smog equipment, and as many cheap mods as i can find
aol s/n: budman8503
GONE MUSTANG HUNTING.......
BACK IN 10 SECONDS
Old Apr 1, 2001 | 08:39 PM
82camaro's Avatar
Car: 82 camaro SC
locker is a fully locked differential, when going straight. Limited slip limits the amount of torque difference between the rear wheels, still allowing slip.
82camaro
Old Apr 2, 2001 | 09:22 PM
KW87GTA's Avatar
I've had both in my car, and right now have a detroit locker in my ford 9 rear. They aren't as bad as people seem to think around turns. They're only really noisey and jumpy if you are going real slow. Like idleing around a turn. And the reason is simple. There is just not enough inertia to unlock the locker. However, I must say there is a big increase in straight line traction. The wheels hook up much stronger and you can get a better launch with less spin if you can get it to the ground. The lockers are not cheap though and this is one big downside. Either way, you're bound to have fun.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed IAC, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
