overdrive @ WOT question.
Old Dec 19, 2008 | 02:44 PM
blp226's Avatar
My 700r4 won't shift into overdrive at WOT. I saw in the tech section why, but there was no info on how to change the "kit modified kickdown valve". Is it something that can be done with the tranny in the car? Other than taking them out and putting them back in, and changing fluid and filter. I know nothing else about transmissions. Any help?
Old Dec 19, 2008 | 03:07 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Re: overdrive @ WOT question.
7-4-V THM 700 81-88 Custom 3-4 Shift valve: Allows max throttle 3-4
shift with 82 to 88 models. Stays in 4th high speeds. From transgo website.
Old Dec 19, 2008 | 03:33 PM
blp226's Avatar
I went to transgo website. There was no provision for purchasing it from them. I couldn't find it at JEGGS or Summitt. Have you baught this part? Did it work well? Where did you get it? Thanks for the help so far. I'm getting frustrated with this stuff! LOL
Old Dec 20, 2008 | 09:47 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
http://www.bulkpart.com/Merchant2/me...roduct_Count=4
Old Dec 20, 2008 | 10:23 PM
blp226's Avatar
Thanks. I appreciate the help. I ordered it today. You've been a huge help!
Old Dec 21, 2008 | 01:34 AM
Pro Built Automatics's Avatar
You can modify the TV plunger sleeve by blocking the two 4-3 downshift passages with Allen plugs. They cost about $0.17 each. You can do this without removing the valve body. There is someone on this board that has the printed instructions of mine up where you can see them. Do a search. I have never done the TransGo way of doing it. But I have been doing it this way for about 14 years now, and it works out well. Dana
Old Dec 21, 2008 | 01:49 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
the bulk part mentioned was a sonnax part# not a transgo
Old Dec 21, 2008 | 05:37 AM
I was addressing 7-4-V THM 700, which is a TransGo part. The Bulk part you are refering to is what I posted to modify on his unit. This modification will save you about $45.00, and do the same thing as the Bulk part. I should have made myself clearer on this. Dana
Pac J
May 17, 2020 10:44 AM
1992Z28!
Nov 19, 2015 07:33 AM
mcfastestZ28
Oct 5, 2015 07:12 AM
Damon
Sep 26, 2015 04:29 PM
Ian Irvine
Sep 4, 2015 08:08 AM
