Will my rear end support LT1 engine ??
Old Apr 4, 2001 | 12:37 PM
mat89RS's Avatar
my gears are 2.73 non-posi unit from an 1989 RS V8 and I'm dropping a 93 LT1 in it.Will it blow up my rear-end if i'm trying 1/4 mile or fast accel. ???
89 Camaro RS Stock as a women with white panties
LT1 IS COMMING SOON.
Old Apr 4, 2001 | 12:42 PM
Aaron87SC's Avatar
If you have wide enough tires to put the power to the pavement without spinning all over the place, you're gonna fry it.
Old Apr 4, 2001 | 01:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The same 10-bolt is used in the 4th gens, and they handle it ok stock but they can break it too.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 4, 2001 | 02:30 PM
mat89RS's Avatar
I running my Bfgoodrich 25560r15 so it should work fine , there's not sticky tires.
Old Apr 4, 2001 | 02:31 PM
mat89RS's Avatar
Thank kevin91z, that's a really good info ...
Old Apr 4, 2001 | 08:00 PM
Aaron87SC's Avatar
Are you sure it's the same 10 bolt with the same gears Kevin? Is it a different 10 bolt than came in the '87? Because if it's the same, it's a damn weak rear. Adding 100 hp to the rear wheels with those 255's would trash the thing pretty quick. At least in my case.
1987 Camaro Sport Coupe LG4
700R4 with 2.73 open rear
Hypertech chip, 180* stat
Dual snorkel air cleaner with K&N air filter
CK rods with B hanger
Hooker catback
Pioneer DEH-P4000, Pioneer speakers front/back
Old Apr 4, 2001 | 11:13 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I thought it was the same rear just slightly modified to help it from distorting so much
Old Apr 5, 2001 | 12:38 AM
mat89RS's Avatar
Will it be better with 3.08 , I'm getting this for free in few days ??? Maybe I can try to find a set of 3.23 of Ebay, I don't know, what do you think would be the best ??? I can probably get a rear-end from a 4th gen, would this work ???
Old Apr 5, 2001 | 01:47 AM
Kevin91Z's Avatar
The 82-89 ten-bolt is 26 spline axles, but otherwise the posi unit is the same style. The 90-92 ten-bolt uses the same posi and gears as the 93-97 ten-bolt. But the rear axle is 4" wider, total, on the 4th gen than the 3rd gen. The 85-89 nine-bolt is stronger yet, but tough to find a good one. Most are 2.77 gears.
Old Apr 5, 2001 | 04:09 PM
mat89RS's Avatar
thanks for the info ...I'll make a junkyard treasure hunt ...
hectre13
Dec 11, 2023 08:14 AM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
