'96 T56 Clutch for installation into my 84.
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Here's what I've got:
'96 Tranny
'84 Camaro with ZZ4 engine (one piece rear main seal)
What I need:
Clutch and Flywheel
#1) Can I just purchase a clutch and flywheel for a '96 Z, since my engine is a one piece crank?
#2) No matter what I do, the SAME flywheel won't fit the ZZ4 and the 400 I'm thinking of building, will it? How about the clutch?
#3) Anyone know of a good clutch that will hold ~400-450RWHP that won't break the bank? I've got about $600 to spend on a clutch and flywheel.
"Beware he who would deny you access to information, for in his heart, he dreams himself your master"
'84 Black Camaro ZZ4 M5 (V-6 in a former life) -- street beast
'91 Medium Blue Metallic Z28 A4 (UB-HSTRY's old ride) -- currently broken
'99 Navy Blue Metallic Firehawk #120 M6 (99.44% stock) -- daily driver
'96 Tranny
What I need:
Clutch and Flywheel
Car: 1991 Camaro Z28
1)The stock LT1 flywheel and clutch will fit the ZZ4 motor.
2)I'm about 99% positive that this same flywheel won't fit the 400 motor.
3)I have the McLeod street clutch disc. It is a kevlar/carbon fiber/asbestos design and should hold 400 hp no problem. It cost me $135 from www.performancess.com Part# 261871. I'm using this clutch with the LT4 pressure plate (actually it's the Centerforce dual friction pressure plate but they are the same thing. The LT4 pressure plate is said to be one of the best) because thats what the transmission had on it when I bought it.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
The flywheel will not fit the 400, but Centerforce and McLoed sell flywheels for your application. You can then reuse the T56 clutch, but the flywheel will cost you close to $300.
Star Performance Engineered Clutches seem to have great parts, service, and reasonable prices. Call them at 1-800-828-4379 or www.specpwr.com
The Centerforce T56 Dual-friction clutch is like $529. Ouch.
I have an SLP clutch which is rated at 40% more clamping power than stock for $340. (732)349-2109 or www.slponline.com
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
