Putting in a BW T-5 in place of my 700R4
Old Apr 9, 2001 | 09:04 PM
86IROCZ's Avatar
The T-5 I have is out of a 91 and it has the electric speedometer in the tail. What do I need to do change it back to the cable driven system. Can I use the sender from the 700r4 or are they completely different systems?
Old Apr 10, 2001 | 05:07 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The 700R4 and T5 use different VSS systems. You need a cable-type speedo VSS from a mechanical T5. I dont know if you can still get one from the dealer but maybe someone has one in the classifieds.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 10, 2001 | 08:08 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Man, If I was at my parents house I could do a swap if you would but, I doubt you would wan't to wait till this weekend and even if you would I would still have to find it. reason being my freind needs an electric vss and alls I have is the cable one.
Old Apr 11, 2001 | 11:50 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
I would probally swap ya I have a vss on my 1992 T5 that is going in my car this weekend but I still need that little housing for my cable operated speedo that goes in place of the vss.. I have fuzzy picture if you want one I live in Iowa.. Let me know Kevin
Old Apr 11, 2001 | 06:23 PM
Engine: ls1, LB9
I will go check this weekend and let you asap.
kjgroen's Avatar
Car: Trans Am
Engine: L69
Ok Kevin
Old Apr 14, 2001 | 09:45 PM
Engine: ls1, LB9
I was uable to find the sensor but, while I was at the junk yard (getting a new diff.) I asked if I could have one out of a camero 86? 2.8 5 speed. so he said sure and now I got the piece that the speedo gears goes on and the cable also atatches too. I hope this is what you are looking for
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
Thornburg
Aug 25, 2015 01:46 AM
Leggman1
Aug 6, 2015 04:15 AM
