Corvette Servo Installation
Old Jan 7, 2009 | 12:09 AM
91Camaro_RS's Avatar
ok so i got a corvette servo w/ longer pin for my 700r4 this is it:
I am gettin a newer transmission to replace the one i have now so i figured why not put in the vette servo before i put the tranny in to make it easier, but i came to the question...how do i put this in...i was told that i take the cover off and there is an entire assembly inside and i only replace the parts that i have new ones to replace them with and then put it back in...and idk if i should use the longer pin or not because i heard that you have to grind it down or something like that, so should i use the longer pin and find the right length and grind it if i have to or should i just use the stock pin?
Old Jan 7, 2009 | 03:23 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Corvette Servo Installation
http://sethirdgen.org/servo.htm
Frozer!!!
Jan 19, 2024 04:55 PM
toronto formula
Nov 10, 2015 06:17 AM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
