tranny problem n possible swap, need help
Old Apr 18, 2001 | 10:57 PM
Slow83Z28Camaro's Avatar
ok i have a 83 z28, n when ever it shifts into 2nd gear i get a loud clunk or a bang , thats when i go around the turn or sometimes even if i floor it of the start, i changed the tranny mount but it still does it but not like it use to.. n e sugestions? i also might be getin a 700r4 of a 88 vette. would that fit rite up to my 305? thanx for the help
80 series flowmaster,8.8, 2.5 in exuast plug wires, accel super coil,accel distriburator, 650 holly n a polished elderbrock rpm performer comin soon
Old Apr 19, 2001 | 04:25 AM
Pro Built Automatics's Avatar
Yes, it will bolt up, but you will have to check out the wiring to the solenoids on the valve body. The 1983's had 2-3-4 lockup (too busy), the 1988's had 3-4 lockup only & this is what you want. The 1988's had many improvements over the 1983's. Make sure you use the torque converter that came with the 1988, it is a 30 spline. The 1983 is a 27 spline.
Hope This Helps!!!
Old Apr 19, 2001 | 04:34 AM
I just noticed you said it is out of a 1988 Corvette? Then the tail housing is completely different & apx. 1" shorter & will not work, and possibly the transmission did not come with mounting holes for the transmission mount. A 1988 & later out of a 3rd gen would work though.
Old Apr 19, 2001 | 02:26 PM
if i get the shaft out of the vette, wil it stil work?
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
