splines and bolts
Old Apr 20, 2001 | 11:10 PM
RedRS91's Avatar
splines and bolts
does anybody know if a 91 camaro RS has 28 spline? im about to order some SLP stuff and i need to know for sure. to use the slp takeoff posi you need 28 spline. its a 10 bolt too right?
Old Apr 21, 2001 | 07:51 AM
ede's Avatar
ede
gm went to 28 spline in 89, but 88 was a transition year so you see both 26 and 28 in 88s, so yes you have 28 spline, or you should if nothings been changed.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 21, 2001 | 10:34 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
According to the parts guy at my local dealer, 28 spline axles arent until 1990. The part numbers for 82-89 10-bolt axles is the same (26 spline), and so is the part numbers for 85-89 9-bolts (also 26 spline).
Yes your 91 RS should have 28 spline axles in a 10-bolt, the SLP take off posi will fit fine.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Nick McCardle
Sep 10, 2015 08:36 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
