Can't find replacement TV cable
Old Jan 14, 2009 | 12:42 AM
ChainHartMachin's Avatar
Car: 01 Z28 / 85 TA
Engine: 346 /355 V8
Transmission: 4L60E /700R4
Axle/Gears: 10 bolt 3.73 / 9bolt 3.27
Hi,
Has anyone found a replacement TV cable at the parts stores? If so what part # was it? Anyone have a last known good GM part number for a TPI TV cable? How about the overall length of the same cable?
I've tried Autozone, Checker and Napa. None of them list a TV / Kickdown / Detent cable for an 88 Camaro or Firebird with a TPI 350. I've tried years older and newer to no avail. I even had a guy at Autozone try to tell me that my 700R4 has a VACUUM MODULATOR!!!
I've also tried GM parts direct, though their catalog is very counterintuitive. I'll try the dealer tomorrow.
Any help would be much appreciated.
Thanks.
Old Jan 14, 2009 | 12:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can't find replacement TV cable
I don't have part numbers handy, but they're certainly available, either as original GM parts, aftermarket OEM-replacements, adjustable universal-fit ones from B&M and TCI, or more exotic solutions from Bowtie Overdrives or Lokar.
Old Jan 14, 2009 | 08:17 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Weird I found them first try.
http://shop.advanceautoparts.com/Pro...on+Shift+Cable
Old Jan 14, 2009 | 01:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those look like shifter cables. He needs a TV cable.
Old Jan 14, 2009 | 01:46 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
You are correct my mistake.
This is what you looking for.
http://cgi.ebay.com/ebaymotors/GM-70...Q5fAccessories
Old Jan 17, 2009 | 08:18 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
tpiparts.net also has them in stock
Old Jan 18, 2009 | 12:53 PM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Also if you dont mind used but still good contact TPIhearse. He had a few last i checked.
Old Jan 18, 2009 | 02:54 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
GM part# 25521263. List price $26.39, wholesale price $18.47. Fits '85-88 TPI engines with 700R4 transmission.
Old Jan 18, 2009 | 04:10 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Id say go on ebay and buy one made by teckpak. I was much happier with their design than the design most parts stores carry. it has interlocking teeth to lock in your setting instead of a spring tension clamp like all the other designs.
Old Jan 18, 2009 | 09:03 PM
sab's Avatar
sab
Car: 88 Firebird
Engine: 406 small block
Axle/Gears: stock posi
i work at napa thats where i got mine. when i go in tomorrow ill get u a part #
Old Jan 19, 2009 | 12:20 PM
1990Camaro1990's Avatar
Car: 1990 Camaro RS
Axle/Gears: not sure???
i found one at a part store oreilleys in my town, cant remember how much but ya... found 1
Old Jan 19, 2009 | 03:13 PM
sab's Avatar
sab
Car: 88 Firebird
summit part# LOK-KD-2700TP. i personally like the lokar cables cause ive had no trouble switching from fuel injection to carb with them
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
