is it possible to bolt a turbo 350 up in place of a 700r4?
Old Apr 23, 2001 | 07:10 PM
hookin88formula's Avatar
what all has to be done to make this work? my 700r4 took a crap and i need something quick and my friend has a turbo 350 just sitting at his house that he said is fresh with a competion kit in it and a shift kit.. so can i just bolt that right in or do i need to do something else to make it work? i do know that i have to get a hold of b&m to get the pin to make my shifter a 3 speed again if i do this. also if anyone knows is there a different bracket that the shifter cabe mounts to for the tranny? also i heard that i will loose low end due to the fact that the 700r4's are geared way different thanks for all the help.. i guess should also ask what are the pros and cons of switching to a different tranny.
1988 firebird ws6 formula350tpi ascd ram air hood GT AUTO 4th gen spoiler black paint with blue pearl centerline champ 500 16x8 all around potenza 245 50 16 on front and 27x11.5 16 mickey thompson sportsman pros on the rear(real sticky!!) msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light A pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter vette servo custom ram air system with a 9" K&N cone filter tb coolant bypass slp runners polished plenum and runners 170* thermostat smog pump and a/c delete plus cat delete march underdrive pullies, tpis airfoil cvr high torque starter (love it) aluminum drive shaft
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system new sticky tires coolant by pass smog removal new runners new thermostat and new three core radiator since i would get to the line and be well over 220* aluminum drive shaft and vette servo
Old Apr 23, 2001 | 08:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll need a different torque converter. You need an adaptor to mount the torque arm. The TH350 detent cable isn't the same as the TV cable. A long tail shaft TH350 (9") can use the 700R4 driveshaft. The short 6" tailshaft needs a drive shaft out of a 82-83 that had the 200C tranny. You'll also need that 200C tranny crossmember.
The 700R4 just has a very low first gear plus the OD. That low first gear helps a car get off the line better when it has something like 2.77 gears in the rear end. If you put some better gears in the rear end then a TH350 will be fine except anything over 3.73's will give high rpms and poor milage at highway speeds. It won't be any worse than a second gen with a 350 engine and TH350 tranny. Probably get better milage than the older cars now because of the EFI systems.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Apr 23, 2001 | 09:59 PM
82camaro's Avatar
Car: 82 camaro SC
Chances are it's a 6 inch tailshaft, especially if it's out of a car. 3000 rpm at 60mph with 3.73's and a th350. 2150 rpm at 60 mph with 3.73's and a 700r4. That overdrive is very nice. The th350 has a 2.52:1 ratio first gear. The 700r4 has a 3.06:1 ratio first gear. The crossmember will need to be modified and/or moved forward a few inches. I wouldn't go through the hassle if it wasn't going to be permanent.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Terrell351
Jun 13, 2021 01:13 PM
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
NWAsonoma
Aug 18, 2015 05:45 PM
