Which valve body?
Old Apr 24, 2001 | 04:25 PM
JoeIROC's Avatar
Which valve body?
I have a 1986 camaro, with a 700-R4 tranny. I am doing a trans-go shift kit, and i purchased a used valve body of the "2nd type". This type has an auxiliary valve body in addition to the main valve body.
I haven't taken my tranny oil pan off yet, an I'm wondering if I might have bought the wrong valve body. I have the shop manual for 1986, and it does not show the auxiliary valve body.
My question pertains to the fact that 1986 700-R4's could have been either 1st or 2nd type as far as i know. Is there any way to tell? Or, should I assume I have the 1st type valve body (without the auxiliary valve body as shown in the shop manual) and exchange the one I bought for a 1st type?
I think the auxiliary type and non-auxiliary type are NOT interchangeable.
I will be doing the shift kit on the valve body I purchase to make installation easier.
Thanks in advance,
Joe
86 IROC TPI 305
700-R4
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
Next mod = trans-go shift kit (level 1)
Old Apr 24, 2001 | 05:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The later valve body can't be used with an earlier transmission.
Old Apr 24, 2001 | 07:31 PM
transfixleo's Avatar
The auxiliary type VB can't be used on a regular case. What was supposed to be so special about it that you were going to change the VB?
Old Apr 24, 2001 | 08:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You are close. It was '87 that got the AUX Valvbody, w/ a few that didn't get one, not '86. All the '86 700's do not have the Aux Valvebody. The two are NOT INTERCHANGABLE.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 25, 2001 | 11:10 AM
JoeIROC's Avatar
Thanks for your help guys, I got it figured out. Dana at Pro-Built gave me the info I needed over the phone. He knows his ****!
Joe
86 IROC TPI 305
700-R4
K&N Air filters
Dyno-Max cat-back
1992 Trans Am
May 10, 2023 07:19 PM
db057
Sep 4, 2015 07:57 AM
lakeffect2
Aug 23, 2015 08:44 AM
crazynights
Aug 21, 2015 06:53 AM
1985chevydude
Aug 20, 2015 12:29 AM
