Power Shifting
Old Apr 26, 2001 | 02:45 PM
bret86z28's Avatar
Power Shifting
I was told that you shouldn't power shift a T-5. Why not? Is it different from other manual transmissions? Can you powershift a T56?
1986 Z28
-black and silver
-t-tops
-305/T-5
-"Big Block Vette" hood from American Sports Car Design
-modified CC Q-Jet
Future Plans
-bigger engine
-T-56 6spd
Old Apr 26, 2001 | 03:10 PM
nestz28's Avatar
Alot of people say not to powershift the t-5 because it is a weaker trans. It's not different than other trannys, and with a mostly stock 305 you shouldn't have any problem with it, but if you have a 350 and a t-5, the extra torque puts much more strain on the t-5 so power shifting is more likely to result in a tranny failure. There is no danger of this with a t-56 because it is much stronger.
'84 Z28 LG4 T-5
'92 Z28 wheels
153,000 miles
Front& rear suspension rebuild using MOOG parts
350 and WC coming in summer 2001
'70 nova 307, th350, all stock, 40,000 mi almost like new
Old Apr 26, 2001 | 08:58 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
power shifting is a lost art to those with horsepower. i would not power shift anything with a cluster like a T-5... maybe even a T-56. have you seen those cluster gears? they are small toothed and weak. i perfer the M-21 Rock Crusher myself, or, n the case of a muncie i perfer a ground-down plymouth cluster gear fitted to work in a muncie 4-speed. they are un-breakable. oh, and don't do any foot-clutch-sliding. T-anythings do NOT like it!
Azrael91966669
25
Jun 20, 2017 04:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
dhonda200
Aug 11, 2015 11:50 PM
